Featured A comparison between nickel metal hydride and lithium ion Toyota hybrid batteries
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Georgina Rudkus, May 21, 2021.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,125
    2,182
    Taylors, SC
    Samuel Williams Jr likes this.
    48,974
    lion seems to be doing pretty well. the track record here is now 9 years, and longer outside n/a.
    i suspect lion batteries are or will soon be cheaper than nimh as usage changes
  3. meeder
    meeder Active Member
    239
    161
    Doesburg, The Netherlands
    The demand for NiMH will get a lot lower so Li-Ion will become cheaper.
    The technology is a lot more mature than 10 years ago. I believe that Toyota has dialed both chemistries in pretty well for their vehicles.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    The simple answer to "Which one is better" probably is:
    Whichever one the car was DESIGNED TO USE.
    Because the electrical characteristics are different enough that they likely won't be interchangeable.......and achieve the same performance.
  5. Samuel Williams Jr
    246
    Dayton NV
    Less weight and more power, sounds good to me. If these guys are still around when our 2 Gen needs it's third HV Battery, it's gonna get one of these.
    Prius Lithium upgrade pack - 14 blocks– NexPower Energy
    I'll let the "techie type's," argue about the "pro's and con's." The market place will shake it out. :)
