A couple of preliminary bZ4X reviews
Discussion in 'Toyota Hybrids and EVs' started by hkmb, Feb 24, 2022.
  1. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
  2. bwilson4web
    16,143
    I have long speculated that replacing the Prius ICE with a bank of batteries would be an excellent economy car compared to the Bolt. But I have no Prius to do the experiment.
  3. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Yes, that could certainly work.
  4. Trollbait
    12,460
    DIY would run into the issue of where to put the batteries. Even Toyota could have issues there with the starting ground clearance, if the goal is over 200 miles in range. Not that a BEV needs that, but it is easier to sell at this time.
  5. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    I think you'll find that my avatar answers that question more than adequately.
    #5 hkmb, Feb 24, 2022
  6. Trollbait
    12,460
    Wasn't that Toyota's solution for the Prius Prime's battery?
  7. bwilson4web
    16,143
    Toyota's commitment to prismatic cells meant they failed to make a tire sized and shaped battery to fit in the spare tire recess. What a waste of interior space. Add to that the use of air cooling ...
  8. Trollbait
    12,460
    I believe Toyota did have a battery that fit into that space. It just had the EV range of the PiP. Toyota didn't want to spend the funds or delay release to properly design a larger pack for the space. Air cooling doesn't help, but the C-max Energi lost less cargo space than the Prime with those same limitations.
  9. Tideland Prius
    16,528
    Also, the IS300h had the hybrid battery in the spare tire well.
  10. bwilson4web
    16,143
    Sorry, I made a mistake as this YouTube shows:
    I thought the Prime traction battery would have fit in the spare tire recess. The Prime body and battery need a redesign.
    #10 bwilson4web, Oct 28, 2022
  11. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    We knew long ago that the battery fit flush in the cargo area. That original plan was scrapped when the final production-lock decision was made to increase capacity to deliver more range. The tradeoff meant it would sit higher, reducing cargo room in back and creating a void underneath. It was interesting to see that happen, since the reverse was done with the prior generation. Remember how the 2010 mule had a 5.2 kWh capacity, then the 2012 rollout had a 4.4 kWh?
  12. mikefocke
    3,962
    1,790
    Sanford, NC
    When auto prices are generally rising, why is the bZ4X's lease price being reduced in its home market? Just inflation in everything making leases harder to afford? Japanese aversion to electricity powering anything? Or the car itself?
    Toyota struggles with lack of demand for their newest EV in Japan but don't read the comments. Worse than political ads.
  13. john1701a
    12,817
    5,303
    58
    It could simply be to get back on schedule. If you want to collect real-world data and that plan was put on hold for 5 months, lowering the price would draw more interest... as well as help overcome whatever uncertainty the recall could have stirred.
