A discussion of gliding and a comparison of methods: pedal control vs. neutral
Discussion in 'Gen 2 Prius Technical Discussion' started by JimboK, Jul 4, 2008.
  1. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    The CAN-View data capture and analysis fun continues, especially on a lazy Independence Day with nothing to do after eating too many burgers ....
    As pulse and glide regulars know, the conventional method of triggering a glide is through go-pedal control -- completely lifting off and feathering back down until all arrows disappear on the MFD Energy monitor. It is fairly easy but takes a bit of practice to hit and hold.
    My CAN-View observations of pedal position values have suggested that a pedal controlled (PC) glide can be executed with pedal position anywhere from 1-10%. Despite the MFD showing no arrows, there actually is a small amount of current flow out of the battery. But interestingly, there appears to be no relationship between pedal position and current flow until after the 10% threshold is exceeded:
    This and my seat-of-the-pants sensations of drag suggest that the car no longer is gliding above 10% pedal position. Presumably the no-arrows condition disappears at that mark, but since my CV uses the MFD for its display, I can't monitor it and the Energy screen simultaneously to verify.
    There is a relationship between speed and current flow with PC glides:
    Some have suggested using neutral for glides. It's easy and requires no practice. After recording these PC glide data, and then observing on the display a fairly low amount and narrow range of current flow (seemingly less than 1.5 amps) with N glides, I have increasingly used neutral -- and, of course, I have recorded data:
    This confirms that current flow moves within a more narrow range than with PC glides, at speeds below 30 MPH. Interestingly as speed approaches 30 it appears to creep up a bit, and then above 30 it's all over the map, even occasionally into the battery. Finally, what's most interesting to me is this blip:
    This is a neutral glide that I let transition to warp neutral (i.e., >40 MPH) coming down a fairly steep bridge approach. It carries me across the bridge and then up a short incline to a toll booth, where the last data point is.
    On this and other steep hills previously I've noticed a brief surge of positive current at speeds around the mid-30s, often spiking to well over 10 amps, along with a simultaneous sensation of increased drag as though I had let it slip into regenerative coasting. (It might have been over 10 amps here too but CAN-View captures data only every two seconds or so, and that's about the duration of the positive surge.) Then something I hadn't noticed before are the fluctuations of current flow in warp neutral being more erratic than most of those at slower speeds. I'd be curious to hear from any of the experts an explanation of these phenomena.
    So the question became: "Which method produces less drag?" With the answer to that might come the answer to this one: "Which method is more efficient?" So I did a head-to-head test of the two methods.
    The test consisted of four runs with each method on a four-lane road through a lightly traveled industrial park. The route is shown here. There was a net elevation decrease of approximately 36' from start to finish.
    I aimed to begin each run at approximately 28 MPH. Each glide was allowed to continue to a defined ending point 0.6 mile from the starting point.
    Outside air temperatures were in the low 90s, and winds were out of the WSW at around 15 MPH -- both as reported by Weather Underground's almanac information for my locale on test day.
    Climate control was off to avoid the significant current draw from air conditioning. Both front windows and the right rear window were opened for driver comfort and ventilation for the hybrid battery.
    Results, with charts for speeds and hybrid battery current flow:
    As suspected, there clearly is more drag with neutral glides than with pedal-controlled glides.
    The CAN-View data capture records battery SOC in half-percent increments. All glides began with SOC between 55.5% and 59%. SOC predictably dropped more with PC glides than with N glides: 1%-1.5% with each of the former and 0%-0.5% with each of the latter.
    So it seems that with lower current flow, N-glides are more efficient, especially between 30 and 40 MPH. I'll hedge a bit by saying this conclusion is subject to correction, given that I don't understand everything going on under the hood as well as some. But it seems generally accepted that use of battery power and subsequent replenishment introduce inefficiencies from conversion losses, and better from an efficiency standpoint is to avoid the battery as much as possible.
    I have incorporated these findings into my everyday driving, using N glides preferentially when safe, especially between 30 and 40 MPH. I use PC glides when preservation of momentum (e.g., heavier traffic) is more important than preservation of SOC, or when I want to quickly alternate between a glide or outright coasting (e.g., timing my approach to a red light).
    It should be stated that using neutral on downgrades is illegal in many states. But states with such a law usually don't seem to have a similar prohibition on using neutral on level terrain or uphill, as suggested by a recent CleanMPG thread on the subject.
    2 people like this.
  2. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    wow. I havent read a disertation so closely since my last class in engineering school!
    You make me desire can-view in my car. also a computer to run o'scope software!
    If I read your charts right- you are actually conserving battery power by coasting in N instead of using the go peddle to go stealth? But you say the drag is more in N. This equates a significantly higher mpg you have found? I would think it would be less! and is their a loss in momentum dropping from N back into drive?
    Fascinating..
  3. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Jimbo, you lying stack of crap!
    There's no such thing as too many burgers!
    Seriously though, that's a VERY impressive write-up. Thanks.
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Very nice job on the measurements, charts and interpretations. Not that I understand them! However each and everytime that I have practiced gliding in neutral ( 3 times maybe) my gasoline consumption was considerably worse. Which puzzles me. Apparently there is some sort of drag, although it is not apparent. I expected my MFD mileage to be worse, as something in the Electronic is not functioning. I also expected my calculated mileage to be impressibly better. But just the opposite. Do a real life check and run in neutral as much as possible, ( a full tank ) and let us know the results. Andy.
  5. JimboK
    2,817
    188
    49
    Chesterfield, VA
    It might be better said that N glides use less battery power rather than conserve more. Hobbit has reported that current flow seen with PC glides in fact is indicating a small push. I suppose you could say a PC glide actually is a low-demand EV mode of sorts.
    There can be a drop in momentum shifting back into D if the shift occurs with your foot off the pedal -- you have regenerative coasting until you begin the next pulse. But what's great for this purpose is that, while in neutral, the pedal is totally disassociated from the drive system. With practice you can learn approximately where to position the pedal for the upcoming glide, and you can have it in position well in advance of the shift. Then the ICE spins up almost immediately with the shift.
    As for MPG results, I can't draw any firm conclusions yet. It seems intuitive they would improve. It is generally agreed that deliberate and sustained higher-demand EV mode operation hurts fuel economy. There is no reason in my mind that this "low-demand EV" would help it. The battery charge still has to be replenished from the ICE.
    My fuel economy has improved recently, but that's to be expected anyway because of summer temperatures. I certainly haven't seen any dropoff. But I am reluctant to say, "Hey, look, my fuel economy is better because of [fill in the blank]" without a controlled test. There are so many variables that affect FE from trip to trip and from tank to tank -- weather chief among them. I'd like to test this with a series of runs on the same day in the same weather conditions, unimpeded and unhurried by traffic.
    Instead of saying there is more drag with N glides (which some may interpret as a negative), my conclusion might be stated better that there is less battery assist.
    Oh, and Tony ... I concede the point. About the burgers, that is.;)
  6. bwilson4web
    16,012
    Many years ago, I read a report about combat aviation tactics and one was 'how to overtake an enemy plane.' The recommended practice is to firewall the throttle while nosing over to reduce lift drag and get a gravity assist. This gets the plane as rapidly as possible to the maximum speed and once the enemy plane is overtaken, climb as needed for the attack.
    I haven't done the math, yet, but I would observe that very small power additions on a downgrade really increases the kinetic energy rapidly. But adding power on the up slope seems only to consume a lot of fuel for very little benefit. In fact, I tend to let my speed slowly bleed off as I try to keep the ICE in a peak efficiency range.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    good stats, excellent charts, but i think a chart covering longer periods of time may be necessary. also, checking stats with 7 bars on battery verses 3 bars might be worth investigating.
    i think we need to look at what happens when the Pri transitions to speeds under 40 mph... the spikes you see, i think have to do with the Pri's engine not turning maybe...occasional charges sent to the 12 volt battery which is my understanding only happens on a "as needed basis" to only charge when the lower threshold is met, and not trickle charged to maintain a small charge level range.
    i dont coast a lot, but there is this one place that dips to a river in the middle of a small valley that i would coast in neutral down one side, using that momentum to get me about half way up the other side before slowing back down to the speed limit, and its simply too short of a range to tell what effect it has and i think your example is too short as well.
    another thing to check, can you check valve timing to see how it changes when speeds transition? or even engine compression?... that last one might be tough
  8. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    I underatand and take advantage of the glide and stealth capabilities of this car every time I drive. (As should every Prius owner).
    I've noticed, and others too have commented on, the almost uncanny ability this car has to glide extensively and maintain speed, and this often was attributed to superior aerodynamics and low rolling resistence.
    In fact, I have felt a slight "acceleration" during a glide, and wondered where did that come from, what just freed-up, or became more efficient to allow that to happen.
    I think JimboK has identified it. There must be some electric assist in there, and that what I've felt.
    In the beginning, I tried N glides while I was getting my right foot trained for effectively manipulating the gas pedal. But, I dropped N glides in favor of PC glide and manipulation because of the easy, efficient and effective transition I can make into and out-of all the modes, linking glides with stealth, and back into glides, thus extending the gas-free momentum and travel.
    You can't do that with N glides, because of the regen induced when reselecting D. To me it's simpler and re-enforces an overall more efficient driving technique to do it all with pedal control.
  9. taxachusetts
    taxachusetts Junior Member
    39
    Boston
    This topic is very interesting if a bit confusing to a brand new Prius owner. Questions: When coasting, or gliding, and there are no colored arrows, is the HV battery charging or discharging? Is the ICE running? How does the no-arrows condition differ from the green- and yellow-arrow conditions?
    My week old Prius is averaging 54.8 mpg. I'm looking forward to increasing that score.
    Thanks,
    Paul, Boston
  10. Neicy
    Neicy Member
    834
    Wakefield, MA.
    Hi Paul,
    Great to have another local on PC. Welcome.
    When coasting, you have green arrows to the battery (regeneration).
    When gliding, there are no arrows at all (no battery use or regen)
    When using battery only, there are yellow arrows going to the wheels.
    When using the ICE (internal combustion engine), there are orange arrows going to the wheels and sometimes (yellow I think) back to the battery (charging).
    John1701a's User Guide (see attachment)is a great resource for learning, as is hobbit's information:
    Hobbit's techie-rants
    I have spent days reading and rereading this info. Each time I grasp more than the last time. Be patient with yourself.
  11. Neicy
    Neicy Member
    834
    Wakefield, MA.
    I have felt that too, and I was on an incline at those times, so it scared me a little (actually a lot the first time) since I didn't expect it and didn't understand what I was feeling. I felt kinda like the car was taking off on me unexpectedly. I was expecting to slow on the incline for a left turn, and as a result needed to brake a little. But this is a perfect explanation.
  12. taxachusetts
    39
    Boston
    Neicy,
    Thanks for the reply. I understand the normal conditions (when the colored arrows are present), but I can't figure out what the operating conditions are when there are no colored arrows.
    Thanks again,
    Paul
  13. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    JimboK,
    Thanks for posting this info. It is an excellent entry point for considering
    what happens in the HSD when gliding. To be honest, I'm not sure that I
    understand what you're saying -- no big surprise as I'm only just conversant
    with the intricacies of the Hybrid Synergy Drive (HSD).
    I've considered what you've said for a whole day. My hope was that other
    really smart posters would come up and offer other perspectives. Well, they
    haven't, and that is the reason that I'm about to reveal my ignorance before
    God and the whole world.
    As gross simplifications, what I understand you to say is, there is an outflow
    of energy from the HV battery when you are in a no-arrows-glide -- about
    1.5% of SOC. There is also an outflow of energy from the HV battery when
    you are in a neutral glide -- about 0.5% of SOC, or 1/3 of the no-arrows-
    glide flow.
    I understand you to say that in both the no-arrows-glide and neutral glide
    the energy from the HV battery goes to providing some small amount of
    forward thrust to the rear wheels. [Edit: should read "front wheels"]
    "Instead of saying there is more drag with N glides (which some may
    less battery assist."
    This is counter to my "seat of the pants" experience. When I have shifted
    into neutral directly from a no-arrows-glide state, it feels like the car picks
    up speed. Kind of like when you're skiing and pass from hard packed snow
    to glare ice. But your speed vs time graph for the two states contradicts this
    -- and for now I'm believing that "numbers don't lie," and neither are you.
    I guess I gotta get my butt checked -- OMG, not another finger wave!!! -- or
    at least get my OEM, used-but good, butt-accelerometer re-calibrated.
  14. grand total
    grand total Member
    154
    ON, Canada
    That would be front wheels. ;)
  15. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Oops, you're entirely correct. It continually amazes me how much stuff is
    crammed under the hood of this car.
    Note to self: Pay attention.
  16. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    I did the side road drive home yesterday using the Neutral Glide (<41 mph) and a few Warp Neutrals (< 40 mph, glide, engine off, then Neutral down a hill up to as much as 45 mph) yesterday. And the Battery SOC stayed up nicely, where it usually drops down to 3 or 4 for this commute. Mileage was less than I had hopped for, average stayed level. I got caught by some out-of-character lights, that usually go green at different times than they did, however.
    Today, I did the highway route. And did one Neutral Glide in a 45 mph construction zone. After putting the car back into Drive, I noticed it would not go into coast. I eventually figured it had to do with getting up over 35 mph, which took about 1/2 a mile due to the slow traffic. After that, I stopped doing the neutral glides, unless I knew I was going to be coming to a stop long enough to kill the engine. Mileage was good, pulled up the average by .5 mpg. And SOC was up a bar from the usual on that route.
    The 35 mph speed requirement for gliding never happens unless the car is quite cool. Temp yesterday was 85 F with a quartering 25 mph wind and sunny, versus about 83F today with a rear quartering 15 mph intermitant wind and clouds. Is it possible the 35 mph glide status is delatched by the neutral glide? Then the last part of the Stage 3B stuff has to recure? This neutral glide was after doing a 10 mile 53 mph SHM cruise, then a 5 to 10 minute slow and go , including a long ramp descent, with lots of short regenerative brake stabs. The lady in front of me in the Audi was driving wierd. Battery temp was 37 C when this happened.
  17. JimboK
    2,817
    188
    49
    Chesterfield, VA
    Me too! I’m a relatively uneducated (in technology, anyway) data geek. ;) I’m on the lookout for those more knowledgeable than I to tell me exactly what some of these data mean, and to correct any inaccurate conclusions.
    You are correct in concept, and probably in the ballpark with 1/3, though I’d be reluctant to pin it down with a precise number. Incremental SOC changes obviously are pretty small. It would be nice to see SOC readings for this purpose at least down to a tenth of a percent. But the CAN-View data capture reports it only in half-percent increments, so there is considerable opportunity for rounding errors.
    After reading your post, I did some additional math on my data. The average SOC loss for N glides was 22% (relative percent, not absolute) of that for PC glides: 0.25% per run vs. 1.125%. Then I averaged current flow and approximate time for each run and figured the average amp-hours used. N glides used 39% of the current of PC glides: 0.091 Ah per run vs. 0.035. But with that calculation comes another opportunity for error. Current flow of course is continuous, whereas CV’s data capture essentially does data sampling. And the sampling interval actually is slightly less than two seconds and seems to vary somewhat. I use two seconds (and state that they are approximate time intervals) for convenience and to keep the math simple.
    I don’t consider battery energy to be providing any push during a neutral glide. The car’s “basal metabolic rate,” so to speak, is close to 1A. I generally run with the radio on, and I did so during these tests, so that adds a few mA. There’s not much further to go to reach the average 1.3A of the N glide runs. EDIT: I am also powering my laptop via a plug-in inverter during my tests, so there's a few more mA.
    On the other hand, as I mentioned earlier, Hobbit states that there is some push with PC glides. The CV data stream also includes battery voltage, so I calculated average battery power for each glide to be 286W for N glides and 820W for PC glides. After converting the difference to horsepower we could say that PC glides provide approximately 0.7 hp extra thrust.
    Thanks, by the way, for giving me the excuse to run these numbers! ;)
    Try this shift mid-glide a few times on a steep hill, and I think your butt check results will be revised. :)
    OK, I’m a little puzzled. I’m not sure what you’re saying about not going “into coast” after shifting into D. And what is the “35 mph speed requirement for gliding” you’re referring to? Since you mention S3b, maybe it’s referring to the speed threshold between S3a and S3b. Finally, what is the “delatching” you’re referring to? :confused:
    Anyway, my tests were all done with car in S4. For S3, as I’m sure you know, you can’t glide below 34 MPH without either an EV switch or beginning the glide above that speed.
  18. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi JimboK,
    Excuse my imprecise terminology. That reference to "coast" was meant to say "glide".
    In cooler weather, well after S4 has been entered (at least once) the car will need to get to 35 mph to enter a glide. Trying to enter a glide below 35 mph does not work.
    My guess is possibly the neutral glide might be resetting to 3B from 4, if something in the drive train is not above some temperature. Most likely the transmission. Or maybe it has to do with time between transmission lubrications (engine operations)?
    "Latching" is an engineering term. When some set of conditions occurs, some systems will set a new operrating parameter, which cannot be undone, ie latched. The most common form of a latch is a relay with a push button to operate the coil, but also contacts of the relay are wired to short out the pushbutton, once the relay is operated. Thus releasing the pushbutton does not deactivate the coil. The relay is said to be "latched". Usually, there is a normally closed pushbutton in series with the relay contacts. Pushing it delatches the relay. On industrial equipment, its common to see a START green pushbutton, and a RED stop pushbutton. This is how the operation of the machine is effected.
    Another similar situation is a vehicle rear window defroster. It will operate after a pushbutton is pressed, but will turn off if the car is turned off, and will not restart if the car is turned back on. This is to avoid draining the vehicle battery, and again this operational logic is that of a latched relay.
  19. JimboK
    2,817
    188
    49
    Chesterfield, VA
    OK, it's starting to sink in. I read on a "See Spot run" level, so it takes awhile sometimes. :p
    I do routinely experience a short episode of the car refusing to glide after entering S4, but it has nothing to do with my glide method -- nor, I think, whether I'm gliding at all, but I can't say that for sure because it's so infrequent that I'm not doing some semblance of P&G at those speeds. Anyway, according to Hobbit, it's from the secondary cooling loop opening to completely heat what remains in the thermos. (I hope I've paraphrased accurately.) But it's not the behavior you describe, which I've never noticed. Instead it refuses to glide (actually more typical of S2) but it resolves spontaneously after a minute or so.
    Having said that, I'll keep an eye out for what you describe, especially as weather starts to cool in a couple of months. It's been only recently and after gathering these data that I've been using N glides with any regularity.
  20. JimboK
    2,817
    188
    49
    Chesterfield, VA
    OK, it's done, at least with one long-ish run with each method:
    The test was performed on this route. The route is mostly four lanes, 45 MPH, lightly traveled, in the vicinity of some industry stuck in the middle of an otherwise rural area. It is relatively flat with some very gentle hills. Net elevation change from end to end is less than 15'.
    Two continuous round trips, a total of 12.4 miles each, were made for each method, beginning and ending at the northern end. That end has a stoplight, so time spent awaiting the light after the first round trip is highlighted on the charts. The neutral glide test was performed first.
    Weather was mostly sunny, temperature around 90F, light winds out of the SW. I used mobile broadband to stay continuously connected to Weather Underground, monitoring real-time temperature and wind readings at the closest weather station less than a mile away. Temperature increased by one degree and wind speed by one MPH between starting and ending the tests; wind direction remained constant. Modeling performed with the Prius MPG Simulator suggests that these changes would mostly offset each other insofar as their effect on fuel economy is concerned, so they were considered insignificant.
    As before, I kept climate control off to eliminate its effect on battery discharge. All windows were opened for comfort and hybrid battery ventilation.
    Hybrid battery temperature, incidentally, held fairly steady. For the N glide test all modules remained at 100F throughout. For the PC glide test, the coolest module stayed at 100F while the hottest ranged from 100F to 102F.
    The pulse range was 15-40 MPH, other than (obviously) leaving or approaching the ends of the test route. A bit of on-the-fly judgment was required, along with an occasional rapid pedal adjustment, in executing pulses approaching the ends, trying to time the speed and distance of those pulses to minimize the need to brake. Braking (predictably) still was required at both ends, but the charts suggest I succeeded in keeping it to a minimum.
    Because of the previously-discussed issue of state of charge (SOC), I attempted to begin each test with an identical SOC. Obviously, however, the tests were not likely to conclude with the same SOC, and the charts demonstrate that to be the case. In fact, one of the more significant data findings (to me) is the steady rise in SOC during the N glide test as compared to the regular undulations seen during the PC glide test. So obviously the charge replenishment seen with the PC test pulses was enough only to offset the discharge during glides -- this despite those pulses obviously producing more current flow into the battery than the N test pulses.
    To adjust for the effect of greater battery discharge during PC glides, I included a period of force-charging at the end of the PC glide test to bring the charge to the same level as where it ended with the N glide test. (Force-charging is done, with the car in “D,” by depressing the brake [to keep the car stationary] and accelerator simultaneously, the latter to force the ICE to light and rev enough to generate enough current to charge the battery.) Here are the various SOC readings via the CV display and data capture:
    Column 1 Column 2 Column 3 Column 4 Column 5
    0 SOC reading N glide[/B] PC glide[/B]
    1 Beginning display 56% 56%
    2 Beginning recorded data 56.5% 56.0%
    3 Ending display before force-charge 60% 55%
    4 Ending recorded data before force-charge 60.5% 55.5%
    5 Ending display after force-charge NA 60%
    6 Ending recorded data after force-charge NA 60%
    The charts show raw ending MPG figures for both tests and the force charge-adjusted MPG for the PC test. With the force-charge adjustment, the N glide test shows modestly better fuel economy.
    Some limitations to the test: Even though the distance was identical and weather conditions nearly so, minor variations in technique and weather could have been confounders. This includes the variations in number of P&G cycles – not surprising, given the greater speed decay and shorter duration of N glides – and the aforementioned adjustments of pulse speed and length approaching the ends of the course. Also, there could have been transient wind speed and direction changes not reflected in the local weather station's recordings.
    So the two methods appear at least comparable for fuel economy, with a possible slight edge in favor of using neutral to glide. With the test limitations and the relatively minor adjusted difference, I still am reluctant to state that unequivocally. A longer test on a closed course with no stops would be ideal, though probably impractical and maybe even impossible in my area.
    2 people like this.
