A few questions, about pretty much everything...
Discussion in 'Gen 2 Prius Audio and Electronics' started by grinthock, Apr 18, 2008.
  1. grinthock
    grinthock New Member
    So i've spent some time searching, and searching and reading, can't really find any specific answers...
    So i've picked up a 2008 with NAV... No XM currently... I'm looking for answers specifically for the 2008 model (I understand the 07 is the same)
    1) The factory XM was $600 (canadian) and I noticed you can get it online for less than $300, does this kit come with everything? do I have to cable it out? Or are the cables there just waiting for hte box... Am I better to just have them do it (At 600, I wouldn't i'd just use an external one)
    2) The bluetooth integration, does the ultimate lockpick 3 fully restore access to bluetooth when moving, including full Caller ID Display (I have a Blackberry Curve 8330).
    3) What's better for full on iPOD integration? The DICE or the VAIS? Any comparison chart? Any compatibility issues linking the DICE/VAIS systems with an ultimate lockpick 3? These systems basically "simulate" a changer and use a strange interface that requires remembering that different CD's change what different options are right?
    4) Has anyone (Canadian specifically but i'll take any experiences) ever brought their LockPick 3 equipped vehicle to the dealer for any form of service and had a problem. Obviously if I had an MFD issue i'd remove it before bringing it in -- but I don't want to bring it in for a simple basic service or inspection and have someone whine.
    Just to mention.... Toyota has stretched these "limitations" too far, there's no way the law is causing it - it's toyota being dicks... I have friends with other vehicles that are not even close to HALF as limited as this thing...
  2. Tideland Prius
    16,445
    1. Toyota's price includes installation
    2. technically, yes. I believe Lockpick 3 is the one but double check by search for "lockpick" in this forum
    3. I have the DICE. VAIS is 2x the price. You can't go wrong with either, seriously.
    4. I don't have a lockpick but I have the EV mod and they don't suspect a thing.. probably because it looks like part of the car (I have Coastal's version).
  3. grinthock
    Little Bump... Anyone else can fill in the gaps ?
