A front end mask will fit on a 2006
Discussion in 'Gen 2 Prius Main Forum' started by stanleyjohn, Dec 12, 2006.
  1. stanleyjohn
    stanleyjohn New Member
    269
    Higganum,Ct
    I installed a front end mask (LeBra) without removing the lower air dam and it fits well with verry miner mods.heres a few pics.Sorry about quality! cell camera.
  2. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    WhoooHoooo!!! :lol: :lol:
    That's GREAT!! Got your message too, thanks stanlwyjohn! We all appreciate the effort, reports, & the pics!
    So, if I order one (LeBra, right?), maybe I can get it on over the holiday when I go down south (where its warmer). Were the mods you had to do on the hooks difficult?
    Anyway, looks Great!! B)
  3. Danny
    Danny Admin/Founder
    7,093
    2,117
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Do you know what the model # is for the LeBra? The PC Shop has access to LeBra products at discounted prices so I'd like to add it to the shop if I can determine which one works.
  4. stanleyjohn
    269
    Higganum,Ct
    Danny! I bought it online from autobarn.The company that distributes and makes the LeBra mask is Global Accessories Inc (customer Service phone no. 516-484-9500).I dont know if there is a model no.but the part no. is 551094-01! I beleive its the same number for the prius 04-07.Hope this helps!.
    Update! global Accessories inc http://www.global-accessories.com/
    Ranger! There are 7 plastic clips on the bottom of the mask that fasten to the ledge under the car.The 2nd one in! from the outer sides of the mask fit right into cars ledge.The other 5 wont because of the bottom air dam.I will try to explain the mod that i did.
    (1)-stretched each of the 5 plastic clips for a good fit and marked on the dam about 1 inch past the center of the clip with a pencil.
    (2)-drilled a small hole small enough to hold a screw(i used a wood screw)
    (3)-screw in the wood screw most of the way into the dam.
    (4)-Take some thick solid wire and make a ring out of it and secure the ends together by solder or looping.
    (5)-Place one end of the ring into the plastic clip and the other to the screw.
    Note! dont make ring to big! You want a tight fit so it will remain on the screw and clip.It shouldnt fall off.If in time it loosens! just make the rings smaller.
    Its a good fit and you cant really notice the mods on the bottom unless your really looking for them.I will try to get a picture of the mod.Hope this help.For me the mod was easy!i do things like this all the time.It really wasnt hard to do. Stan!!
    Update!!!! Heres a few pics of mod!
