A little Prius PM + a BIG thank you to NutzAboutBolts for the vids!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kc410, Mar 12, 2017.
  1. kc410
    kc410 Active Member
    262
    251
    2010 Prius IV
    2010 Prius - 205K - finally got around to a little PM from under the car.
    1) Changed coolant in both engine & inverter circuit.
    2) Changed transaxle oil.
    3) Cleaned AC evap core.
    This was the second coolant change. The first was at 100K when I purchased the Prius in Nov 2013.
    The inverter coolant was still a bright pink & at the full level in its reservoir.
    The engine coolant had lost its bright color, but was still pink. Its reservoir had lost about 2/3 of its coolant.
    I had not touched either of the coolant systems, just monitored their level regularly (105K).
    The transaxle oil I had previously changed around 125K. On this first change it was quite black. On the change today I could still see the red color around the edges of the oil & was not nearly as black.
    86K on Michelin Defender tires (always at 44psi) - Getting a new set tomorrow from Costco.
    Still on original brakes - that is my next & hopefully last major thing to do for at least another 50K.
    #1 kc410, Mar 12, 2017
    NutzAboutBolts likes this.
  2. Spenny
    Spenny Member
    82
    25
    Ill echo your praise, he is quite awesome and responsive. Is he a member on here? I always just comment on his videos.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Congrats on the mileage(y). I hope to be there in 2 years.
    You said the coolant was green? Do you know what was in the reservoir? Was there green coolant in the inverter loop as well?
  4. kc410
    kc410 Active Member
    262
    251
    2010 Prius IV
    Trying to type & watch TV at the same time - coolant is & was pink - corrected in post - thanks :)
    Mendel Leisk and Raytheeagle like this.
  5. ChapmanF
    15,659
    Engine coolant level should not have dropped like that ... hoping maybe you weren't totally thorough bleeding it last time, and it just burped later? Do you happen to remember how you went about bleeding it last time?
    -Chap
  6. kc410
    kc410 Active Member
    262
    251
    2010 Prius IV
    At 100K the dealer changed the coolant (as part of the purchase deal).
    For the last 105K & 3+ years I had not touched or opened either coolant system, just kept a eye on the levels.
    The engine coolant level just went down very slowly over the 3+ years & 105K of driving.
    The engine coolant level appears to be staying steady since I filled it on Sat.
  7. Mendel Leisk
    38,733
    Kudos for the write-up, and good to hear the Defenders are long-lived! I have a set in the garage for our son's Civic, when the snows come off.
    PM means Preventative Maintenance??
  8. kc410
    kc410 Active Member
    262
    251
    2010 Prius IV
    Yes
