A New Complaint
Discussion in 'Gen 2 Prius Main Forum' started by daniel, Jun 7, 2004.
  1. daniel
    14,487
    1,518
    Spokane, WA
    I don't believe I've seen this commented on before. But it appears that in order to change the temperature setting of the climate control, it is necessary to turn on the blower fan.
    This is an issue because with the temp set high, hot air will come out of the vents even with the fan off. In order to stop this, I have to turn the fan on, then lower the temperature setting (which requires holding the button for a fairly long time, or pressing it repeatedly to lower it one degree at a time).
    In spring and fall, when it is cold in the morning and warm in the afternoon, it is not enough merely to leave the heater off in the warm afternoons: Rather, I have to turn it on, bump down the temp setting, and then turn it off again.
    I'd like the temp buttons to function even with the fan off. And I'd like a single button that would bump the temp in one press to Max Hot, and another for Max Cold.
    And I've mentioned this before, but I'd like another button that, in one single press, would set the system to bring in outside air directly, without either heating or cooling it. To accomplish that now, you have to fiddle with the controls until you have outside air, A/C off, and the temp set below the car's inside temperature.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Daniel,
    I think it's a fairly valid complaint. It's not just that the blower comes on, the AC comes on as soon as you activate that temp button and there's no single button/one push option for the vent setting--which I find ludicrous. :roll:
    It's an amazingly efficient system, with essentially one or two quirks that should be easily fixed--1)One-button vent 2)temp control without activating auto-AC. :|
  3. Brian
    Brian Member
    480
    Bakersfield
    Maybe they think that If you are changing the temp of the air that eventually you are going to turn it on, So why not have them start it for you.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    It's possible to have the setting on "fresh" while keeping the blower off. If you keep the temp all the way down, the car shouldn't heat the air that comes through either.
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    I think essentially the engineers designed the "climate" system around the Auto setting. almost everything else is an afterthought.
  6. daniel
    14,487
    1,518
    Spokane, WA
    In summer I can keep the temp all the way down, and in winter all the way up. But in spring and fall, when nights are cold and days are hot, I have to go through the whole temp-changing routine twice a day.
    If I've had the temp high for a cold morning, then when I start the car in the afternoon, even with the fan off, a considerable amount of hot air comes out. Unless I remember to turn the temp down before I shut it off, which still puts me through the whole hassle.
    In my old '89 Civic, the temp setting was a big knob, and a quick flick of the wrist. Fresh/Recirculate was a slider that stayed where I left it! Sometimes the old mechanical controls really are better.
    Of course, I could set the temp on 72 and always use automatic. That way I'd burn gas to run the air conditioner when an open window would do just fine.
  7. windsurfdog
    windsurfdog New Member
    67
    Northern Gulf Coast of Florida
    I believe the extra gas one would use when the windows are open and aerodynamics are not maximized would negate the extra gas used to power the a/c. Just set it on 72 and forget it or turn it off and roll down the windows. Either way, make sure the hippopotamus is comfortable.... :D
  8. daniel
    14,487
    1,518
    Spokane, WA
    The aerodynamic effect is negligible for city driving. On the highway I agree with you and always close the windows.
    Thanks for thinking of the hippopotamus. He's been so quiet back there lately that I'd nearly forgotten about him.
  9. m4prius
    m4prius New Member
    59
    Ohio
    why not leave the blower always on the lowest setting...that way you can always make the temp change...I always keep the blower on the low setting in my other Toyotas...you need to flush the air out of the duct one way or another...adjust the vents so the air doesn't blow directly in your face during start up.
  10. Frank Hudon
    4,147
    another nice feature of the Classic, just turn the knob and it's set
  11. delrey
    delrey Member
    280
    SF Bay Area (East Bay)
    Well I also have to agree with the complaint, thought it doesn't bother me too much (I just keep the auto setting around 72, bump it up or down a little as needed).
    I think I've used the voice command once or twice to switch from max cold to warm ... but hardly ever have it on max cold ...
  12. DaveG
    DaveG Member
    806
    Vancouver, BC
    I don't think I've touched the auto-climate setting on mine more than a couple of times since I found the sweet-spot where I like it (23.5c).
    It would be nice to have two or three "temperature preset" locations though, that you could just tap to recall temperature/vent combinations.
    Dave
  13. norman
    norman New Member
    77
    Australia
    Well I always leave it at the same temp and let the CC take care of it. After all, isn't that what it's for?
    It strikes me as odd how my wife cranks up the house heating when its raining outside as though the house will heat up faster. In fact it heats at the exact same rate no matter what the thermostat is set to, it just continues to heat past that low "simmer" where I start to sweat, but she still shivers.
  14. Batavier
    Batavier Member
    442
    The Netherlands
    3 points for the hippopotamus in the back!
  15. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    Must be the engineers in Japan never come across a (Let's sing it all toegther) "Dead skunk in the middle of the road". I use the outside/inside buttons in my Odyssey a lot during the non-winter months. Works well when following a stinky old deisel dump truck too
  16. delrey
    delrey Member
    280
    But there *is* a single button to switch to recirc!
    Used it every time we passed the stinky bit in the recent 3 trips up and down hwy 5 to Los Angeles and home again.
    (I wonder how many people become vegetarian after driving by a feedlot?)
  17. windsurfdog
    67
    Haven't found a recirc system that works better than the Prius.....skunks, diesels, smoke just don't get in as long as one gets to the button on the steering wheel quick enough.....extremely convenient.
  18. N9IWP
    N9IWP New Member
    148
    Southeast MN
    The problem with "set and forget" is that there are days when it is 60F in the morning so you want to heat it to say, 68F but 85F in the afternoon so you want to cool to say 78F. (or it is 80F but sunny so it is 90F in the car)
    Brian
  19. victor
    victor New Member
    414
    Gilching Bavaria Germany, & Drapanos, Crete, G
    I dont know if this would work (as Im still waiting) but have you tried playing with the driver profiles? Maybe you could set one for hot and another for cold air? Just a thought.
