A picture album of my wiring install.
Discussion in 'Gen 4 Prius Audio and Electronics' started by Gas Mizer, Aug 13, 2018.
  1. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    I remember someone was asking about how to wire an amplifier on the gen4. I ventured the attempt this weekend. I did finish, but I didn't think glamour shots would be helpful. This link is to yesterday's photo album through Google Photos. Enjoy!
    https://photos.app.goo.gl/FPFbQa3ZR8spjmWK6
    krmcg, qettyz, jerryxsara and 3 others like this.
    51,669
    wow, that was a labor of love, well done!(y)
    Since2002 likes this.
  3. Depe
    Depe Junior Member
    33
    23
    Tennessee
    Four Touring
    Great job! I didnt get that in depth with my sub install over the weekend.
  4. G23
    G23 Junior Member
    28
    How did you drill the hole in the firewall. It doesn't look like you can get a drill in there straight against the firewall. What kind of drill did you use? I have a cheap cordless 12v drill. Do you think that would be strong enough to get through the metal? Is that 4 gauge power wire? Thanks!
  5. G23
    G23 Junior Member
    28
    Also how did you figure out how to disassemble all the interior parts and the wiper cowl?
    #5 G23, Aug 23, 2018
  6. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    Just diving in. There's not much to them. Most of the interior is held together with snap clips.
  7. Radiospank
    Radiospank Member
    166
    77
    i'm confused, where is the battery located? front or back?
  8. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    The front.
  9. G23
    G23 Junior Member
    28
    Any tips on drilling the firewall hole? From the inside or outside? I would think from the outside in that location, but how did you get the drill in there? extension? did you have to drill at a downward angle? Thank you.
  10. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    I drilled from the inside. I couldn't get the drill close enough from the engine side. It was very slightly at a downward angle, but the grommet ring and wire still fit through, luckily.
  11. Radiospank
    Radiospank Member
    166
    77
    I don't know if the 4th gen is the similar to the 3rd gen in the firewall boot area, but when i fished some wire through the boot I just sliced an X and pushed my wire hanger through. The material is very easy to cut so be careful.
  12. G23
    G23 Junior Member
    28
    Did you use an extension of some sort. I assume you went through the speaker opening. I cannot get the drill close enough from the inside. Also, any tips on getting the wiper cowl off? I have the instructions and was able to get the arms off, then the corner pieces. I'm stuck at the point where you are supposed to use the molding remover to pop it off. I have a similar to the one pictured but I cannot get it off. Thank you.
  13. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    I just pulled on it. You can feel where the retaining clips are by the give that the cowl has. Try and pull as close to those as possible. As for the inside, I had the upper part of the dash off, which also just pulls off.
  14. krmcg
    2,592
    2,392
    Whittier, CA
    Now I know for sure why I leave this type of work to the professionals.
