A Pillar removal for 2020 PP
Discussion in 'Prime Main Forum (2017-2022)' started by ccna101, May 29, 2024.
  1. ccna101
    ccna101 Member
    94
    27
    SFO/IAD/DCA
    2020 Prius Prime
    PC folks,
    I am ready to hardwired -2-fuse for front dashcam ... I am avoid run wire across the curtain airbag.
    Any one had access to the driver side A pillar removal installation ?
    TIA,
  2. ccna101
    ccna101 Member
    94
    27
    SFO/IAD/DCA
    2020 Prius Prime
    Alright, I took the bait and pop it open...
    Remove negative battery terminal for 30+ minutes.
    Pop the door shield, pop the upper interior A pillar.
    Turn white plastic latch 90 degree to slide out the top.
    The bottom latch is pop easily .
    Be careful when you working near the curtain airbag.
    That is all folks .
  3. Mendel Leisk
    38,644
    Ah, the A-pillar cover. Here's me thinking you were going to get out the reciprocating saw... :eek:
    ccna101 likes this.
