A "Problem" Triangle Mystery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ahay91, Feb 12, 2017.
  1. ahay91
    ahay91 New Member
    Seattle
    Hello, While I was on the road today, my car displayed the red triangle of death, check engine, and a few other dash lights. I pulled off to the side of the road and car quickly died.
    Towed to mechanic, voltage read 3.5v, they charged the battery (it seemed to hold a charge they said) and two codes came up: C2300 Actuator system malfunction and C2318 Low voltage error. Mechanics test drove the car and it ran fine after charging the battery. They couldn't replicate any problems and sent me on my way.
    I'm about to go on a cross-country move and would be terrified that my car would stop accelerating while on the highway. Any other things I can check to find out what this problem is? Today I used MFD to test the voltage of the battery after not driving for the past 1.5 days, and it was at 11.9 in ACC mode. Also, for context, I haven't driven the car more than a joy ride about 2x/week this winter. Do I need a new battery, or just drive more often, or something else, any more ideas or tests to try? thank you.
  2. JC91006
    16,496
    8,406
    Get a new battery if it's more than 5 years old. I would do it if I were to make a cross country trip, preferably a couple weeks before
  3. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    What JC said.
  4. ahay91
    ahay91 New Member
    Seattle
    Thank you for your replies. I purchased the car 6 months ago, so I'm not sure how old the battery is. Is there any other test I can do before replacing to make sure this is the problem? The auto shop said to keep driving and see if the problem happens again, as it could be inverter or something else. That scares me a little with the upcoming trip.
  5. JC91006
    16,496
    8,406
    There's usually a date code on the battery itself.
  6. bisco
    49,720
    how many miles on her? what would make a battery drop to 3.5 volts? i think it's toast, but you can check with auto parts places to see if anyone can do a load test.
    jerrymildred likes this.
  7. ahay91
    ahay91 New Member
    Seattle
    Thank you, I will check out the battery to see if I can find a date. There are about 146k miles on the car. Indeed, what would make a battery drop to 3.5v? That is what I am wondering.
  8. bisco
    49,720
    perhaps the mechanic did not have a prius specific reader. it's worth diagnosing the battery, then getting proper codes if it is still acting up.
  9. jdenenberg
    jdenenberg EE Professor
    3,860
    1,859
    Trumbull, CT
    2020 Prius
    LE AWD-e
    As an insurance policy, get a jumper battery and take it with you on the trip. It will act as a temporary battery if your existing one is toast. Besides, mine has an air pump which can also be handy on a trip.
    JeffD
  10. ahay91
    ahay91 New Member
    Seattle
    These are both good ideas. I spoke with some auto shops today and it seems firestone is offering the super start battery for $180 plus $15 installation. thats only a little bit more cost than buying a jump box... sounds like a good deal unless I'm missing something.
  11. bisco
    49,720
    if it's an exact fit, go for it.
