A question for all owners of Gen II Prius on this forum
Discussion in 'Gen 2 Prius Main Forum' started by mickeyrom, Mar 15, 2010.
  1. mickeyrom
    mickeyrom New Member
    kewanee,il
    Has anybody actually had a UA incident? Even one time?
  2. halpos4
    halpos4 "Taxi"!
    377
    24
    Ireland
    After 281,000km.....No!!
  3. PRIUS007
    PRIUS007 James Bond -007
    133
    Mundelein, Illinois
    From what I've seen and been able to find, not really.
    I know I've had mine for over two years now (exact length of ownership is in the signature line) and never had anything ever happen like this.
    I'm one of those that 'just about anything is possible' but with as many Prius' that are on the road today, if there was an issue or several cases, you'd sure think you would have heard of it by now.
    Especially since the Prius is the 'poster child' for Hybrid vehicles.
    Lots of good information posted on this here:
    http://priuschat.com/forums/gen-ii-...-probe-cause-runaway-prius-in-california.html
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Nope, all my accelerations in 120k miles were are intended.
  5. ljbad4life
    ljbad4life New Member
    365
    24
    149k miles later and never one incident of UA or Brake quirks.
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    YES! My left foot twitched and the car accelerated! Must blame Toyota!
    Of course not! This is just all very silly. The most likely part in the car to fail is the nut behind the wheel. Please investigate that FIRST!
    Now I suppose it's -possible- to trap the accelerator pedal with a floor mat, but that is the OWNERS responsibility. Toyota supplies the clips, and the dealer should have clipped the mat in when he delivered the car. If he didn't it's -HIS- responsibility, not Toyota's. In my case, I have that mat clipped in, and on top of it I have (in winter) a Weathertech mat. -I- take responsibility to ensure that that combination -can't- trap the pedal, and it didn't in all the tests I've done on it.
    Prius didn't get the corroding throttle pedal modules. They all got the Japanese ones.
    To say the electronics could fail and cause this is just silly. If it fails it stays failed, and that will show up in subsequent tests, and so far, we haven't heard of that. Even a firmware glitch would show up. Don't you all think Toyota have been testing that ad infinitem? THEY DO want to find out what's happening. It's necessary for sales. ;)
  7. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    No, but I only have 29,000 miles, most on cruse control.
  8. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    210
    San Diego, California
    13 months with no problems
  9. Roger3125
    Roger3125 New Member
    199
    Orange County, So Calif
    2006 with 30K and no problems BUT I request clarification if I may...Todays paper said "the Prius is designed to shut down if the brakes are applied while the gas pedal is depressed"
    1. Does the gas pedal have to be all the way to the floor for this to go into effect?
    2. Is this true for all Gen II Priuses
    3. Will it damage the Prius if pushing BRAKE while the the car is going at a high speed? Not that i care but am curious.
    Looking forward to today's Toyota announcement!
  10. KTPhil
    KTPhil Active Member
    1,379
    110K, five years, and no UA.
    The Prius does not shut down when the brake and gas are pressed together. Try it at a stoplight. The engine revs up a little but (maybe 1500 RPM?) and the car goes nowhere.
  11. randalla
    randalla Member
    370
    Lexington, SC
    2004 since new with 85000 miles and nada!
  12. Politburo
    Politburo Active Member
    971
    208
    The car will stop if the gas is pressed first, then the brake is applied.
    What you describe is called "force charging" and is allowed by design.
    As for my experience, no UA in the Prius at 23k.
  13. alfaplastics
    alfaplastics New Member
    IL
    I have not had any UA issues with 153,000 miles although I did have some minor braking issues when the rear drums were not cleaned on a regular basis. In wet conditions the rear drums sometimes sounded like there was metal to metal contact and the ABS would come on no matter how easy I applied the brakes. I take the car in for a brake check and they would clean the rears and it would be good as new.
  14. dogfriend
    7,512
    1,185
    Carmichael, CA
    There is one thread started last May, where there was a claimed unintended acceleration with a Gen 2 Prius.
    http://priuschat.com/forums/gen-ii-...nintended-uncommanded-acceleration-issue.html
    As mentioned above, it won't work by design when the car is stopped. It does work though. I have tested at approx 40 mph.
    To try it - accel to some road speed, floor the accel pedal with left foot, then brake firmly with right foot while holding the accel pedal down. Listen to the engine noise; it will drop rpm from high rev down to idle speed within a sec or two. My car will come to a complete stop from 40 mph in less than 3 sec. Once stopped, you can rev the engine but the brake will hold the car stationary.
  15. blippo
    blippo New Member
    255
    VA
  16. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    2004 with nearly 95,000 miles. Only time I had an issue was last April when my floor mat pushed against the gas pedal. This is before ALL the hoopla and I had the presence of mind to realize what was happening. I pulled the mat back and then hooked it properly when I stopped the car. Only reason this happened was because the car wash clerk failed to secure the mat after cleaning the car.
  17. Roger3125
    199
    Thank you but what you say and I've confirmed to be true contradict what the LA Times said. Again...
    ""the Prius is designed to shut down if the brakes are applied while the gas pedal is depressed"
    unless,of course, they failed to mention "above a certain speed"
    Confused as ever like the rest of us
  18. desertrider2215
    156
    usa
  19. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I am not confused, I am sorry you are. There does not seem to be any confusion on the part of actual Prius owners here, they all report no UA in their Prius. (the topic of this thread)
    I am sorry a newspaper article confuses you, I have found newspapers poor at technical details myself.
  20. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    No confusion here. Applying the brakes while the gas pedal is depressed WILL cause the gas engine to power down AT ALL SPEEDS in the Prius.
    If the gasoline engine is going a few thousand RPMs while the front disc brakes are heavily engaged, this will over-rev and BURN OUT the MG1 electric motor in the transaxle. A destroyed transaxle is a very handy way to slow down the car.
    So the Prius has a computer system that cuts gas engine power to protect the transaxle from getting destroyed when both the gas pedal and brake pedals are pressed at the same time, and a transaxle that will get destroyed (and consequently stop the car) if somehow the computer system fails to cut the gas engine power when both pedals are pressed.
    Either way, your Prius WILL stop when you press both pedals at the same time. It will stop normally if the hybrid computer is working, or it will stop via transaxle self-destruction if the hybrid computer is NOT working.
    EDITED TO ADD: For the record, no problems in my '07 since I bought it new back then.
