A spare full-sized tire method
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Mambo Dave, Mar 26, 2022.
  1. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    In my two years here, I keep seeing questions about how to get this done. I've seen some use the OEM spare tire parts, with a donut spare, and some at a great cost when buying new.
    My goal was for cross-country trips where I don't want to have to wait a weekend for the correct sized hybrid tire, and where I won't necessarily have to limit myself to the recommended mileage max for those little spares.
    Bought a used full-sized wheel off of ebay, then bought a new full-sized tire.
    Bought stiff enough foam that I can load multiple 24-packs of canned drinks, etc. and not really notice the compression - but at the cost of it sitting a bit high when not loaded.
    Can't recall if this is 5" or 6" foam.
    A board across the front to prevent the foam from moving too much:
    There are two threaded holes built into the cross-brace, so that's all I had to use, but for its purposes it is absolutely fine:
    So preventing the jack, tire iron, etc. from becoming dangerous projectiles during a crash or rollover, I used velcro straps to secure those items to the wheel/tire. The whee/tire is, of course, bolted to the spare-tire threaded hole to keep it in place. This image should be rotated clockwise one quarter turn.
    Without gear on it, the top can sit proud. This is never an issue, though, as I always have enough gear to compress the foam to about the tire height.
    #1 Mambo Dave, Mar 26, 2022
    JLX, ETC(SS) and bisco like this.
    52,390
    well done, thanks!(y)
  3. PaulDM
    PaulDM Active Member
    616
    319
    UK
    2022 Prius
    Excel
    Have you thought about using a space saver? That would
    make the boot lie flat.
  4. Mendel Leisk
    41,901
    It is too bad they didn't make the spare tire well slightly more generous; it almost fits a full size wheel/tire.
    Mambo Dave and PaulDM like this.
  5. PaulDM
    616
    319
    UK
    2022 Prius
    Excel
    Agreed. If you have to use the space saver and put the full size in the space it lifts the base by 3-4 inches
  6. Mendel Leisk
    41,901
    I think it’s the OD that hangs up on the sidewalls of the well first. Not sure but other’n that maybe depth is ok. I recall seeing mention of full size spare in some owners manual. Might be 4th gen, and it was euro spec?
  7. PaulDM
    616
    319
    UK
    2022 Prius
    Excel
    Both my gen 4’s have had a space saver even though the manual said full size for the 2019 (2020 states spec)
  8. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    Not my experience with the 15" tire, OEM size, in the spare-tire hole. It's just too wide of a tire - meaning its width is the issue when laying down by increasing the height of the floor. The circumference is fine.
    #8 Mambo Dave, Mar 29, 2022
    JLX and Mendel Leisk like this.
  9. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    So that extra padding became a boon this weekend. Rained-out tent camping had me use the rear of the Prius as an RV bed on Saturday night. I left the car running, AC on "Auto" to have the car self-regulate the engine and HVAC. I used a one-inch sleeping pad on top of it all, and got a better sleep than I did out in the hot and humid air the night before.
    3rd3rd and JLX like this.
  10. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    I just realized I missed taking or uploading pictures of the tire/wheel securing method.
