a sweet smell
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bobkat21, Feb 11, 2006.
  1. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    every now and then someone smells a anti-freeze smell around my car.i don't know if the car is running hot becaus no gadges and no poddles of anti-freeze on the ground. also the resavor is not down. anyone having the same or simaler problem. i'm taking it in monday...
  2. aaf709
    3,862
    2022 Prius Prime
    Interesting. What year and how many miles?
  3. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    if it was overheating you'd get a warning.
    recent coolant service? hit any road debris?
  4. Spunky
    Spunky New Member
    469
    Could be a pin hole in the heating core.
  5. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    okey it is a 2005 and has 32,000 miles on it
  6. Zacher
    Zacher New Member
    236
    OR
    Sownz bed!
  7. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    that is a no to the road debris and no to recent coolent service also
  8. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    foxy if I have a pin hole would I not be low on the anti-freeze? I am not low on it nor have I put any into the resavor
  9. Spunky
    Spunky New Member
    469
    You say people smell it "around" your car. Only when outside or do you ever smell it in the interior?
  10. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    Foxey its inside and out side but here is the kicker its not all the time. it's were and there.
  11. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    Foxy its inside and out side but here is the kicker its not all the time. it's were and there.
  12. Sho-Bud
    Sho-Bud Member
    190
    Amsterdam, Netherlands
    Window washer fluid ????
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    do you park your car by itself? if not, i wouldnt worry about it. you say you checked all your fluids and they are ok. maybe you should have your parking lot mates do the same for their cars.
  14. Spunky
    Spunky New Member
    469
    If it's a pin hole then the level of antifreeze would decrease very, very slowly. It would be hard to notice the change.
  15. Stairman
    Stairman New Member
    42
    If you have a pinhole in the heater core, you will only smell it when you use the heater (or when the climate control uses the heater.) You wouldn't notice the level drop because only a few drops will be lost, and only when the heater is on. On the other hand, if it is the heater core, I wouldn't expect to smell it outside the car.
    Try turning the heat way up, and see if you get the smell in the car.
  16. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    I'LL GIVE THAT A TRY... IT'S NOT GOING TO HURT RIGHT LOL THANKS ALL
  17. Spunky
    Spunky New Member
    469
    Cool. Hope you diagnose the problem soon. Let us know.
  18. Frank Hudon
    Frank Hudon Senior Member
    4,147
    there are two resivours for the cooling systems (two) on the Prius. The tank up by the inverter is for the Hybrid cooling system and there is another on the top of the radiator for the ICE cooling system. Also a very small leak that will just wet a small portion of the radiator is enough to "smell" things up.
  19. Spunky
    Spunky New Member
    469
    Frank, you rule! :)
  20. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    OKEY ALL I WENT TO THE DEALER TODAY AND THEY PUT IT ON A PRESURE TEST FOR 45 MIN AND NOTHING . BUT WHEN I WENT LATER TO PICK UP MY BROTHER . HE SMELT IT AGAIN . THIS TIME I HAD THE HEET ON HOW DO I GET THE DEELER TO LOOK AT THE HEATER COAR. I JUST DON'T KNOW RIGHT NOW !!!!!
