A weird Sound from the engine - Prius 2017
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Mohammad Shanti, Jul 3, 2020.
  1. Mohammad Shanti
    Mohammad Shanti New Member
    Jordan
    Hello
    I have Prius 2017 middle east - Gulf standards, recently I heard a sound like cracking or gears friction in the bottom of the engine when I shift the gear on neutral and push the car manually backward or forward is it a serious defect ? Dose any one face the same?
    Thank you
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    You may get something like that after you wash the car. You will notice it the first time you move the car after washing, but then it will go away (until the next wash!)
    alanclarkeau and krmcg like this.
  3. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    Lift the car and spin the tires while off the ground. This should give you more information.
