A whole lot of noise to wake the neighbors just to step out and get my paper
Discussion in 'Gen 4 Prius Main Forum' started by Cynthia Johnson, Mar 31, 2020.
  1. Cynthia Johnson
    Cynthia Johnson New Member
    COLORADO
    2020 Prius
    LE AWD-e
    My new 2020 Prius makes an awful lot of noise when I step out while it is still turned on to get my paper or the mail. If I can set it to a quieter beep when it is locked can I reduce the volume on this programmed loud sound also? I’m used to my quieter 2006 Prius. Do I have to turn it off in order not to wake my neighbors on either side of my concrete garage access townhome alleyway at o dark hundred just to step out and get my paper?
    Mambo Dave likes this.
    51,935
    what sound does it make?
  3. Mendel Leisk
    41,457
    Turn it off?
    kithmo and kenoarto like this.
  4. schja01
    schja01 Senior Member
    1,834
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    It’s the beep (Toyota calls it a buzzer) for opening the door in ready.
    It’s a warning for a good purpose.
    Just press the on/off button prior to exiting the car? No harm no foul.
    kenoarto likes this.
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    I really don't understand what you are describing. Can't you pull up to the mail box, put the car in Park while the door is still closed and then open your door and get out without the car making a noise? Granted, if you close the door with the car in Ready taking the fob with you, it will beep to indicate you are leaving a car in Ready without a fob present. But leaving the door open, it should not make any sound assuming you have the car in Park. At least that's the way mine works. Maybe the new ones are different.
    Cynthia Johnson and dig4dirt like this.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm a little unclear as to the situation where you would need to use your Prius to obtain your mail or newspaper. In other words why is it necessary to activate the lock/unlock function at all?
    BUT...I think the heart of the question is...
    " If I can set it to a quieter beep when it is locked can I reduce the volume on this programmed loud sound "
    My answer is I know of no way to adjust that volume.
    I wouldn't necessarily take this as a definitive answer, others may, but to my knowledge there is no "easy" or direct way to control that volume.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Mine will NOT "alarm" if you leave the drivers door OPEN while it is running and the FOB moves away.
    But mine is a C so others might work differently.
    But......like others have said, if what you are doing really IS a significant problem........STOP doing that. :whistle:
    Cynthia Johnson likes this.
  8. Trollbait
    12,539
    Some housing developments have multi mailbox units instead of individual ones. Big ones are like a wall of the boxes at the post office, but weather proof.
    For the OP, the solution is to turn off the car, as mentioned. If you don't want the engine coming on, hit the EV button after starting the car. This is literally the type of situation Toyota envisioned for giving the first Prius an EV mode.
  9. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Leave the key fob or the extra key fob in the car while you get out of the car. Mine does that if I leave without shutting off the car. But it’s for a good reason since some people will just leave and never shut off the car. Next thing you know the battery is drained and the car starts up while parked in the garage.
    iPad ? Pro
  10. The Electric Me
    9,083
    5,801
    I guess what I missed is the OP's declaration " when I step out while it is still turned on ". Since I'm assuming it's not necessary to have the vehicle ON to obtain your mail or paper, the easiest solution is to just turn off the Prius. I'm also assuming you can't drive or need to have your Prius on while getting your mail or paper.
    Since I know of no way to adjust the volume...I think the answer is to simply turn your vehicle off, which I always think is a good idea if you are not in it.
    kenoarto and Trollbait like this.
  11. bisco
    51,935
    there might be a way to adjust the volume on a 2020 model
    when i start my gen 3, open the door and get out with the key in my pocket, it doesn't beep. if i close the door, it beeps 3 times.
    i wouldn't call it a whole lot of awful noise
    #11 bisco, Apr 1, 2020
    krmcg likes this.
  12. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    There is no adjustment. It's there as a safety feature.
    If you happened to have it in "D" or "R", it would firstly beep to alert you as you open the door - for obvious reasons that the car will drive away (if the handbrake wasn't on - which a lot of PRIUS drivers never use). Though - I could be wrong, but I think if you open a door, it drops it into "P" if the vehicle is stationary.
    Then, if the car is running, it alerts you that it is running, probably a valid thing - I remember reading before I bought mine 3½ yrs ago about someone sat in his PRIUS in the airport carpark checking his mail etc, got out of the car, left it in PARK, mustn't have locked it either and flew away for 4 or 6 days. Came back and it was still running, nice and cool inside, but the fuel tank had reduced considerably.
    All because the legislative nannies (and grandads) don't trust us.
  13. bisco
    51,935
    what sounds does it make?
    alanclarkeau likes this.
  14. FuelMiser
    1,349
    929
    Monument, CO
    I don't believe this solution will even work if the ICE is still in it's warmup mode: 1) it won't go into EV mode until after warmup AND 2) you run the risk of developing the SHAKING syndrome if you power down with the engine still running in warm-up mode.
  15. Cynthia Johnson
    COLORADO
    2020 Prius
    LE AWD-e
    A number of loud beeps as Toyota intended. I would like to lower the volume as I was able to with the horn when the car was locked using the fob from outside.
  16. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    ...and they shouldn't! Your story is a perfect example of how easy it is to forget to turn off a vehicle when the ICE is off. Even the OCD gear-head driver, who hears everything, would (casually) think it's already turned off.
    kenoarto and alanclarkeau like this.
  17. Cynthia Johnson
    COLORADO
    2020 Prius
    LE AWD-e
    Thanks for the warning. It looks like i can turn it off after coming home from work to pickup the mail but not when the car is just warming up and coming out of the garage. But I am getting older. If I can remember to put it in EV mode then I can also remember to look for the paper before getting in the car. Does not always happen. Sometimes on cold mornings I want to open the garage at the last second to keep from freezing my roommate out in her room above the garage. Maybe I should just leave the paper in place until my return and read it online.
    I was not in my 2006 Prius. It sure is in the new one.
    I will try it while leaving the door open
    #17 Cynthia Johnson, Apr 2, 2020
    Mambo Dave and bisco like this.
  18. ETC(SS)
    7,157
    Pretty much asked and answered.
    I'm thinking that your alternatives are slim.....like turning the car off before you get your mail or going for a nice, refreshing, morning walk before going to work.
    This is presuming that one of the "features" of your G4 is the fact that it will howl in protest if you leave it on while exiting the car with the fob still in the car.....
    I drive an old-school wireless G3.
    It will wait patiently and quietly for me if I leave it running while going inside an office...which I NEVER, EVER DO because it would be against company policy... ;)
    I'm not sure about this but I'm thinking that in the 130 year history of the automobile....idiot drivers did not start with Priuses - social media memes notwithstanding.
    ....and they won't stop being idiots when the last Prius on earth gets turned into beer cans..
    Besides....dot.gov isn't responsible for the nannynunciator....it's the car company hiring lawyers to keep idiot drivers from suing the car company. I'm aware of no government regulation requiring that cars have exterior annunciators to notify people that they've committed the travesty of exiting their car with their key fob in their purse or pocket while it is booted up.
    Now.....the parking lot annunciators are a MUCH different thing....but that's dot.gov getting paid by the pound to legislate.
  19. bisco
    51,935
    can anyone here with a g4 detail the neighbor waking commotion it makes when opening the drivers door and getting out while in park and ready?
  20. bisco
    51,935
    have you tried counting them, or is continual until you get back in and close the door?
