A2DP Bluetooth Audio Delay
Discussion in 'Gen 3 Prius Audio and Electronics' started by Beven, Jul 19, 2011.
  1. Beven
    Beven New Member
    Outside Boston
    Hi all --
    So I've just noticed this on my new phone when pairing to my 2010 Prius...
    When using Google Maps/Waze and pumping thru audio via Bluetooth, what should sound like, "Turn left in 1.5 miles" gets cut to .."five miles..." Seems that there's a delay by the time audio gets pushed thru the phone to the unit.
    Anyone have this happen?
  2. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I noticved the same thing while I was wasting time waiting on my boy's scout meeting. I watched a movie via Netflix on 3G, through the car audio, and there was a slight lag. Didn't make the movie experience any worse.
  3. nguyenvht
    nguyenvht Junior Member
    evansville, IN
    How do you get your A2DP bluetooth streaming audio to work in the first place? I can make a receive phone calls through the bluetooth, but haven't been able to play music through it.
  4. JoelIrwin
    JoelIrwin New Member
    63
    Houston
    For phones that are also a2dp, you should only have to pair once through the display such as I did with my iPhone 4. If you are using a non-phone bluetooth a2dp device, see if that devices identifies your car on its display. Both devices need to be put into a discovery mode to find each other and do the pairing.
    If you have never gotten a2dp to work or can't see the car in discovery mode on your a2dp device, check to see if the feature is available for your model at all.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    BT audio streaming is only available (in the US) with nav.
