Aaargh!!! TPMS Registration!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, May 17, 2016.
  1. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I finally replaced my scraped-up wheel with a wheel I bought from a wrecked Prius. I took it to a wheel shop and the buy put my tire onto the new wheel and balanced it. I kept the TPMS sensor that was already on the wheel, and figured I could use Techstream to register it when I got home.
    It never occurred to me that I had to write down the serial number that was on the TPMS sensor before mounting the tire onto the rim.... So now I have a TMPS warning light on my dash and I can't make it go away. Is there any way I can get the sensor to register without taking the tire off the rim and reading the sensor's ID number?
  2. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    You can use Techstream to blank out the tire and turn out the light. But unless you can get the code from the wrecked Prius, AFAIK you gotta deflate and read. do not know if a Denso code setter can read the code, but Techstream you need to feed it the code.
  3. Rebound
    3,964
    2,613
    Portland, OR
    I entered an all-zero code in Techstream, but the light still comes on
  4. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I had a sensor I didn't know the ID of so I went to a local tire store and they had a tool that could read the ID and display it without having to dismount the tire. You could call some in your area and see if they have such a tool and would be willing to take 5 minutes to use it on your new sensor.
  5. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I know nothing about tire sensors, so I'm curious, why would you have to reregister an existing sensor? All you did was move it from one wheel to another wheel and put it back on the car. How does the car know it was moved to a different wheel?
  6. Mendel Leisk
    38,725
    Just to follow this thought, it would be really funny if the problem was actually low tire pressure. :ROFLMAO:
  7. Rebound
    3,964
    2,613
    Portland, OR
    The wheel I bought already had a sensor on it, so I didn't think I'd need to pull the old sensor off and put it on the new wheel.
  8. Mendel Leisk
    38,725
    Swapping the old sensor in should resolve this then. You can test this by putting the old wheel with sensor in the hatch for a while, the light should go off. Just make sure the tire's got pressure.
    You do have the old wheel and sensor?
  9. Rebound
    3,964
    2,613
    Portland, OR
    It may be. But Techstream reported 1 PSI pressure, and it can't be that low
  10. Rebound
    3,964
    2,613
    Portland, OR
    Definitely. But what a PITA.
  11. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Sorry, I misread your statement thinking you were talking about the original wheel, so I get it now. I'm surprised the installer didn't suggest keeping the original sensor or ask if you needed the serial number for the replacement, I would have.
    Rebound likes this.
  12. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    Did you see my thread on Managing TPMS with Techstream over on Gen2 Maintenance? I tried Code 0000000 and that seemed to turn light off for about 2 weeks, then it came on again. I assume another sensor went bad on me (old), but I will check. The other "cheat" approach might be to give it the code of a working sensor.
    How do you know which tire to reset the code?
    Unless you know which tire, AFAIK you have to go around and reduce pressure and watch the screen to see which tire is which. It does take a few minutes for the data to update and the Techstream does not show immediate reaction to pressure changes and code changing. Data needs to refresh.
    As far as theory, I did read there is some privacy concern with TPMS as in theory a roadside reader could track vehicles. That implies the ID code is transmitted.
    #12 wjtracy, May 17, 2016
  13. Mendel Leisk
    38,725
    I'd just live with the light; that's taking cargo cult to new heights.
  14. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    That's one approach but I am trying to play with it with Techstream just to see what hacks are possible. Also I am curious to see how long each sensors last.
  15. Rebound
    3,964
    2,613
    Portland, OR
    I tried the seven zero's trick. No luck.
    Three of the sensors read about 40 psi and one reads 1 psi. That's the unregistered one. Techstream lists the registered numbers, and I compare it with the number on the sensor from the wheel I swapped out.
    I'll just go back to the tire shop and have him scan the code or swap put the module.
  16. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    OK...if that battery is TMPS dead I think you get NA reading...so the implication is the old TPMS still reading. I was also wondering if there is some way to pressure up the old TPMS to fake out the reading.
  17. Rebound
    3,964
    2,613
    Portland, OR
    I know what I need to do. I was just hoping I could do this with TechStream
  18. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    You will have to pull that SOB serial number out from that wheel, there's no other way lol... sorry that this happened. I think you can go back to the tire shop and have the guy deflate the tire and squeeze the tire down for you to write the serial number down.
    krmcg and Rebound like this.
  19. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    I am sorry the "zero" technique did not work ...I will try to get on Techstream soon to try it again on my Gen2 to see what is going on.
  20. Rebound
    3,964
    2,613
    Portland, OR
    No worries. I'd assumed that I could just start Techstream and tell it to register the new sensor. I'll get it squared away...
