Abnormal up shifting and down shifting.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by h1ph0panonymous, Feb 25, 2025.
  1. h1ph0panonymous
    h1ph0panonymous Junior Member
    95
    17
    69K miles 2014
    Started noticing abnormal shifting patterns during subzero temps going downhill around 47 mph, almost like it was engine braking. Would down shift into lower gear when it was fine in the gear it was already in. Started doing it when weather was warm as well. Was the transmission just adapting to my winter driving or do I need a transmission flush (11 year old car, don’t know if it was done already as I bought it two years ago at 39k miles). Could it be hybrid battery related? It’s not a rough gear change but it’s noticeable in the MPG gauge when it’s drops gears. When I go on the highway it won’t get into the proper gear until I’m up to speed and let go of the accelerator.
    What is this a symptom of exactly or possibly?
    Should I wait to see if the transmission learns my warmer weather driving?
  2. PriusCamper
    PriusCamper Senior Member
    11,977
    4,870
    Pacific Northwest, USA
    The Prius doesn't down shift or upshift... The Hybrid Synergy Drive is a planetary gear system with some electric motors that both provide rotational force as well as the ability to generate electricity from existing rotational force.
    The closest thing a Prius has to the feel of down shifting or upshifting would be if the battery is drained down or too cold to use more than lightly, causing the gas engine to work harder (higher RPM), which would feel like down shifting. Or when the battery is fully charged and engine power isn't needed as much (lower RPM) which would feel like upshifting.
    If there's something wrong with this system an app like Dr. Prius app via a $20 OBD2 reader would give you the data for that.
    h1ph0panonymous likes this.
  3. ASRDogman
    ASRDogman Senior Member
    7,113
    3,713
    There are NO gears in the CVT. So there is not shifting.
    And there is NO flush either. Just drain and refill. But the car must be level so you'll have to
    raise the front and rear of the car. And remove the FILLER plug first!!!!
    You need to get a good code reader and see if there are any codes.
    You could likely have issues with the plugs, or bad fuel.
    It sound like you are not getting full power from the engine.
    Check your air filter, engine air filter. It could be clogged, or dry rotted.
    There are also sensors to clean...
  4. h1ph0panonymous
    95
    17
    Makes sense, yeah battery was failing to go into EV mode when coasting below 43mph per usual, assuming because it was way too cold 0 degree average last week here in Minnesota but how we have a heat wave. It would go into EV mode after like 20 minutes of higher speed driving. EV is working normally now in warm whether with fewer instances of the “impressions of abnormal shifting” but still happening. Maybe just have to recycle the battery, drain it and charge it a couple times? (Does this on its own in the summer due to the battery energy cost of having the AC on when idle).
    Otherwise start looking for a new hybrid battery rather than a transmission flush or both eventually seeing how old it is?
  5. PriusCamper
    11,977
    4,870
    Deep cycling NiMH can restore a battery at 50% capacity back up to 96%. Usually needs to be done every 18 months on older packs. It takes lots of patience.
    Hybrid Automotive and Maxx Volts sell products to do this. Or you can build your own: Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
  6. h1ph0panonymous
    95
    17
    Would you recommend a drain and fill just due to its current age, assuming it never had one?
    I have a scan gauge II so no codes were showing and I would force clear even without any showing.
    I think like another commenter said that I should try deep cycling the battery which I can try by letting it idle with AC on then drive around once depleted once a day.
  7. h1ph0panonymous
    95
    17
    Will do thank you, although not a proper deep cycle but I’ll just try to drain it once per drive and recharge before turning it off for the day.
  8. ASRDogman
    7,113
    3,713
    It won't go into ev mode over 26mph.
    If you suspect the hv battery, you should do a test.
    The Dr. Prius app can do that. Or if you have techstream or the D8, those can test it.
    You shouldn't randomly discharge/charge the battery. You can't really do that with out the
    proper equipment. You can get the Prolong system to do that.
    The computers will only keep it between 20-80% state of charge. So unless you turn the car off
    when the engine starts, or leave it in neutral, the battery won't get very low.
    You should also check the other things I mentioned. Put some fuel injector cleaner in the fuel also.
    Since you don't have much mileage, there are several things it could be.
    You may have to find a GOOD Prius shop that will go over the car and find the real cause of your issue.
  9. ChapmanF
    17,182
    Sure, gears don't slide around and mesh and unmesh, but c'mon.
    A transmission is a thing that lets the ratio of engine rpm:wheel rpm change. In my last stick-shift passenger car, those ratios worked out to:
    • 1st gear: 14.02 (you'd hit 2500 engine rpm at 12 mph. 5300 at 25 mph)
    • 2nd gear: 7.561 (2500 at 22 mph, 5300 at 47 mph)
    • 3rd gear: 5.295 (2500 at 32 mph, 5300 at 67 mph)
    • 4th gear: 3.768 (2500 at 45 mph, 5300 at 95 mph)
    • 5th gear: 3.001 (2500 at 56 mph, 5300 at 119 mph)
    An engine at 2500 rpm sounds like it's doing good honest work, and at 5300 (top rpm a gen 3 Prius ever uses) it's got a nice howl to it.
    In any transmission, whenever the transmission changes <whatever> so the engine revs higher at the same road speed, that's a downshift. When it changes <whatever> so the engine revs lower at the same road speed, that's an upshift.
    The Prius transmission can cover that whole range of ratios in a continuously-variable way instead of with 5 fixed steps. But the range of ratios it gives between the engine and the wheels is pretty much the same range, and what you hear when the engine sound goes higher for the same road speed (downshift effect) or lower for the same road speed (upshift effect) is pretty much what you hear in other cars, except it doesn't go in fixed steps.
    For example, when I was testing my gen 3's engine braking on a hill in Indiana, it hit 3936 engine RPM down the hill at around 36 mph, and the sound and the feel were about the same as my older stick-shift car would have sounded and felt if I downshifted to 2nd on that hill at that speed, which is about what I would have done in that car.
    The nifty details of how our transmission does that inside doesn't mean we have to stop people from saying 'upshift' or 'downshift' when they know what those sound like in other cars and their ears are hearing the same thing.
    #9 ChapmanF, Feb 25, 2025
    h1ph0panonymous and PriusCamper like this.
  10. PriusCamper
    11,977
    4,870
    Lol, yet again you're disagreeing with me without actually saying anything that's in disagreement with what I said. Please stop trying so hard to be argumentative!
  11. h1ph0panonymous
    95
    17
    Would you recommend a transmission fluid dump and refill just based on age of car and seeing that it never had a dump and refill based on logical reasoning of said facts (miles when bought)?
    Also I’ve been cheating out and only filling 10 bucks worth of gas each time, hasn’t seen a full tank in a couple months. I usually add Techron to the fuel tank the times I do fill it up which is once or twice after an oil change, could be related?
    Otherwise it’s battery related which I’ll see if I can ghetto deep cycle it.
  12. ASRDogman
    7,113
    3,713
    See post #8
  13. ChapmanF
    17,182
    I wouldn't connect it in any way with the symptoms described here. The oil in a Prius transmission is only there to lubricate things and carry away some heat. In some other automatic transmissions it plays a role in controlling the works, but not in a Prius.
  14. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    When I first got my prius, it was doing the same thing you describe here.
    I quickly thought to change out the ATF.
    After having that done, the issue was resolved.
    Sometimes it is experience with the exact issue, that will help you get to the answer.
  15. Mendel Leisk
    40,457
    Certainly.
    An opportune time to replace the transaxle fluid is around 10k miles or a year. I've done maybe 3, and with the first, around that interval, the fluid was darker than any of the subsequent drains. The last one I resolved to leave it alone for a good long time. My conclusion: the main benefit is to drain the manufacturing debris, and from then on it's much more stable.
    More info in my signature. On a phone turn it landscape to see signatures.
  16. h1ph0panonymous
    95
    17
    Do you know the exact name or type of fluid needed for the Gen 3? Also, transaxle or transmission, or are they the same term lol?
  17. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    08886-81210 Toyota ATF WS
  18. Mendel Leisk
    40,457
    There’s a transaxle fluid change link in my signature. (On a phone turn it landscape to see signatures).
    Toyota refers to the Prius gearbox as “transaxle”.
    Your owners manual stipulates Genuine Toyota ATF WS fluid, and cautions that use of anything else may damage the transaxle.
  19. ChapmanF
    17,182
    Not just Toyota, that's the industry-wide term for any gearbox that combines the transmission and the final axle drive. Typical on a front-wheel-drive car.
    h1ph0panonymous and Mendel Leisk like this.
  20. Mendel Leisk
    40,457
    Yeah I do notice various spell-checkers auto-complete "transaxle".
