About to hit 100,000 on 2004 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by illuminati480, Jan 20, 2008.
  1. illuminati480
    illuminati480 New Member
    Casa
    About to hit 100,000 on 2004 prius any thoughts? Anyone hit 100,000 yet it is all interstate mileage.
  2. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Thoughts on what? Just keep driving it! ;) And congratulations for the milestone.
  3. Godiva
    Godiva AmeriKan Citizen
    10,339
    Gee. I've got a 2005 and I just crossed 25,000.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i'm at about 90k miles on my 04. i'll see ya at 100k before the year ends... i think.. hehe
    no problems with mine.. except for aftermarket wheels that are not balanced right.
    I wonder if it's even possible to remove the sparkplugs... ouch... i should have broken them loose around 50k
  5. Sp33dy_gr33n
    Sp33dy_gr33n New Member
    31
    Midwest
    Thank goodness that you are driving a Prius and not a Hummer.
  6. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 is at 106,000. There are about 6 2004+ Prii at or above this mark in the Green Hybrid Mileage database.
    JeffD
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Be sure to post up in THIS THREAD.
  8. LRP114
    LRP114 Little Lou
    26
    Silver Spring, MD
    NO, I am only at 35,000 miles. I wonder if you would mind sharing your maintenance experience with me and others, so have a better idea of what to expect?
    Have you had to do the following and about what miles or age of car:
    o 12V battery;
    o (motor) air filter;
    o other mechanical or electronic parts;
    o brakes (front/rear); and
    o any other items done, and at what miles/months of use?
    Little Lou
  9. Devil's Advocate
    922
    Las Vegas, Nevada
    The only real maintenance I would recommend is a transmission/transaxle flush and fill and coolant flush and fill. Maybe spark plugs, but not really neccessary.
    The rest of the car is pretty much maintenance free, just check all the wear items.
  10. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Your mileage sounds about normal, but I think it is considered low miles compared to the average commuter in the US. I have almost 3K on my '08 and I've had it for almost 2 months now.
  11. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    If you are a DIY like myself, you may want to replace your belts too in addition to what was mentioned on the above posts. Perhaps think about replacing your shocks and struts, if you have the extra $'s.
  12. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    don't flush anything. drain and fill.
    belts plural? there's just one. might as well replace it though.
    probably a good time to bring it in for a good inspection to see how everything's wearing. suspension should still be pretty good but make sure they check em for oil leakage.
