ABS Accumulator keeps leaking (C1391)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by m_saad47, Apr 23, 2019.
  1. m_saad47
    m_saad47 New Member
    Pakistan
    I've got a 2011 Prius with 120k KMs on it. ABS Accumulator leak error C1391 appeared about 2 months ago. Since then I've replaced the ABS accumulator 6 times, each accumulator lasts 3-4 days before the ABS warning lights show up and the error reappears. Could there be some other underlying problem which would lead to low pressure/leak in accumulator other than the accumulator being faulty itself?
    51,154
    welcome!
    i have no idea, but i'm wondering, are these new oem units?
  3. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    #3 The Critic, Apr 23, 2019
  4. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Was the par replaced a new one, or used?
    Two logical reasons why you're having this problem might be that the part your replaced, is/was also defective.
    Secondly, might be a wiring harness issue on the abs pump connector area.
    Thirdly, were you the one that replaced the part, or a dealer?
    Was the abs system bled of air from the system, and the codes cleared, after the install?
  5. ChapmanF
    17,347
    Yes, absolutely! The accumulator and the actuator are separate units in Gen 3. The accumulator pumps up and stores pressurized fluid, but almost all of the valves and passages through which it could be leaking down are located in the actuator, not the accumulator. Both parts are expensive enough that there's generally a strong incentive to try to pin down which one is at fault in a particular case before busting out the wrenches.
    That requires some human detective work. The ECU can give you the code saying "hey, the accumulator pressure isn't holding up" but it has no way to gather enough information to tell you why.
    After six accumulators, a case could be made that it's probably the actuator in this instance.
    Gauravxxx and Robert Holt like this.
  6. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    Albert Einstein is widely credited with saying, “The definition of insanity is doing the same thing over and over again, but expecting different results.
  7. ChapmanF
    17,347
    Dxta likes this.
  8. theory816
    theory816 Member
    112
    23
    I'm purchasing an accumulator soon. Is there an easy way to bleed it or do I need special software?
  9. Mr. F
    Mr. F Active Member
    386
    253
    Washington
