ABS actuator - does it need immediate replacement?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brka-brkb, Jun 7, 2025.
  1. brka-brkb
    brka-brkb New Member
    Washington, DC
    Hello!
    My 2009 Prius with 192K miles started making the dreaded "turkey call" noise, which I'm told is due to a struggling ABS brake actuator.
    This obviously could/would be a safety issue, except my car doesn't (yet) display any warning lights and this noise only happens *after* I come to a full stop, and only when I step on the brake FULL force, as far down as it would go. And there is no brake fluid leakage, either.
    Would you say that at least for now, my car is safe to drive? I do plan on being responsible and address the issue when more serious signs emerge.
    Thanks!
    51,013
    you're fine, and it could be a long time before it needs replacing, no way to know.
    even if it goes out, you still have manual braking, but be prepared to put all your weight behind it.
  3. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    I drove with a failed brake actuator for a year and a half long stop distance but no problem we just have to remember. All that honking I would bleed brakes
  4. PriuSocal
    PriuSocal Member
    146
    29
    SoCal
    I purchased my 2nd gen from someone who had this issue and was being quoted $3500 at the "STEAL”er. He drove it for 6 months as is (stiff brake pedal) and I drove it from 125 miles home as is PLUS, drove it for another 500 miles until I eventually replaced the actuator. If you can i’d say replace it as it's def a safety issue and depending on wether your family rides in it or not, its not that hard a job to not tackle it and depending where you are…you can find the actuator fairly cheap or buy a whole car with another issue for about the cost of a repair on this. If you’re close to @Tombukt2 ask him, he appears to get find them all the time (whole cars)
