ABS actuator replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gjkristi, May 10, 2016.
  1. gjkristi
    gjkristi Junior Member
    24
    I have a 2010 Prius and according to Toyota the ABS actuator is bad for a tune of 4000.00 dollars parts and labor. I have a rear sensor error and the cruise control will not work( I believe because of the ASB not working). I can get a used one for under 200.00. Is there a way a person can do this at home? I have worked on cars all my life and am quite handy. I under stand that you need a scan tool to bleed it after replacement but have seen some people bleed by doing it manually by turning system into maint. mode. If someone is knowledgeable on this or has done this on a gen 3 I would like to hear your advise. Thanks Gregg
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    1st step is to get fotga techstream and cord from ebay
    49,460
    mini vci and an old windows laptop. ^^^
  4. gjkristi
    24
    Thanks for the reply. The techstream is needed to bleed the brakes after actuator replacement?
  5. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    According to the service manual, there's a non-techstream way.
  6. gjkristi
    24
    There are a lot of VIC mini techstreams out there does it matter which one or certain version?
  7. gjkristi
    24
    Cr94 have you ever bled brakes using this method? I have seen this on youtube and looks like it should work
  8. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    No I haven't, by either method. Still trying to decide whether to attempt changing the fluid myself as I have on normal cars, or be a coward and have the dealer do it. Somewhere on this site there's a post with a pdf attachment of the relevant section of the official service manual.
  9. Former Member 68813
    3,524
    981
    US
    there is a sticky with youtube video on bleeding without TIS.
  10. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    It's actually quite easy to bleed the brakes manually :)
  11. gjkristi
    24
    Replaced the Actuator and now have many codes c1203,c1392,c1364,c1345,c1247,c1246 I think it needs to have the actuator bleed. I do not know if the manual bleed will fix this. I have ordered a techstream and will have to wait to bleed it.
  12. gjkristi
    24
    Thanks everyone, All is good I bleed the ABS ECU with the techstream software which was a little tricky but got it done.
    Moronical likes this.
  13. gjkristi
    24
    You can only bleed the ABS thru the techstream software (or similar software).can't do it manually.
    tankyuong and NutzAboutBolts like this.
  14. NutzAboutBolts
    1,476
    1,552
    Bay Area
    Glad to know and glad I bought one lol
  15. James Analytic
    180
    28
    Michigan
    Did you wind up buying a Mini VCI and if so, vers 1.4 or 2.0?
    Also, what version of techstream did you use and what computer?
    Any suggestions regarding which MiniVCI to invest in?
  16. NutzAboutBolts
    1,476
    1,552
    Bay Area
    I bought one but never used it.
    James Analytic likes this.
