ABS actuator replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tom Bean, Mar 22, 2022.
  1. Tom Bean
    Tom Bean New Member
    Idaho
    Just wanted some advice on an ABS actuator replacement issue. After putting it all back together I get no change in the warning display signs, but most importantly it doesn't go into reverse or drive. Do I have a connection not fully engaged, or something else?
    49,431
    did you disconnect the hybrid battery safety plug?
  3. Tom Bean
    Tom Bean New Member
    Idaho
    Yes if that is the orange connection in the trunk. I thought I connected it correctly afterwards.
  4. JC91006
    16,480
    8,397
    There’s a really important step about bleeding the brakes after you’re done. It’s usually done with a computer and compatible tech stream type software
  5. Tombukt2
    Tombukt2 Senior Member
    9,073
    1,573
    Durham NC
    When you did this did you have to disconnect the inverter in order to move it to replace the actuator or the pump or whatever or is this on the other side of the car that you don't have to touch the inverter?
  6. JC91006
    16,480
    8,397
    inverter has to come out on the 2nd generation actuator replacement.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    3,454
    1,502
    NJ-USA
