  1. Amy P
    Amy P New Member
    Yesterday
    Indiana
    Would anybody in Indiana be able to replace an ABS actuator on a 2007 Toyota Prius? Code C1256, Code C1391
    #1 Amy P, Aug 26, 2024 at 6:52 PM
  2. Tombukt2
    Tombukt2 Senior Member
    9,625
    1,686
    Durham NC
    You got all the lights on the dash The accumulators running all the time or the pump is running trying to pump up the accumulator all the time so on You're in Indiana I'm in North Carolina so I probably can't really help but any idiot generally speaking that works on cars should be able to make this happen in about four and a half hours never doing this before It can watch a video and see basically what needs to be done My daughter could probably do it but you wouldn't want to get her hands dirty she likes working on PCs so there's always these things If you watch the video a couple times on how this is done a whole lot to it You only going to need a few wrenches and a few sockets and long needle nose 45° angle pliers that you can buy at Walmart maybe a pickup magnet would be good to have and make sure you have a pair of channel lock type pliers and that's about it watch the video you'll need to take the plug out of the HV battery because you're going to have the top off of the silver inverter and on and on and on The person that's doing this will probably need to have some sort of scan tool that can perform the brake bleed function for this model they should make sure this before they start
  3. ChapmanF
    15,872
    Where in Indiana? If you're anywhere near Scottsburg, maybe check with Autobeyours.
    Brian1954 likes this.
