Abs and Vsc light after brake replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tony714, Sep 14, 2019.
  1. Tony714
    Tony714 Member
    103
    17
    Orange County
    Hey guys. I am In the weeds here. Just performed a front and rear brake replacement on a 05 Prius and silly me thought it was just a simple replacement.
    Now the ABS light, the VSC light and the e-brake light are on, and brakes are at like 75%.
    What did I do wrong and how can I fix it.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Have you tried pulling the 12 volt battery lead for resetting the codes?
    Did anything occur during the work?
    JC91006 likes this.
  3. Tony714
    Tony714 Member
    103
    17
    Orange County
    Normal replacement, but only after did I read I had to pull the ABS relay.
    The brake function really worries me.
  4. JC91006
    16,478
    8,394
    Did you do rear brakes or front? Why would it be at 75% if you changed them?
    Raytheeagle likes this.
  5. Tony714
    Tony714 Member
    103
    17
    Orange County
    Front and rear. And hoses so I had To bleed. And by 75% I mean performance, before I had solid brakes. Now they are barely functioning.
    And the e brake, abs and Vsc light are on
  6. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Brake actuator original?
    Had issues with this previously?
  7. JC91006
    16,478
    8,394
    Oh you bled, that's the problem. The car requires techstream software to bleed, electronic brake actuator
  8. Tony714
    Tony714 Member
    103
    17
    Orange County
    No idea. Bought the car four months ago and no brake problems previously. I changed the front disks and pads last night and did the rears today. Bled the system and it just popped up.
    If I disconnect the battery, what am I facing there?
  9. Tony714
    Tony714 Member
    103
    17
    Orange County
    Soooo if I dont have that, what do I do?
  10. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Find someone who does;).
    In SoCal that isn’t so tough:).
    But if you pull the 12 volt, it resets the computers, so it’s a chance to start fresh(y).
    JC91006 likes this.
  11. Tony714
    Tony714 Member
    103
    17
    Orange County
    I have heard that pulling the battery requires various resets. Any thoughts on that Ray?
  12. Tony714
    Tony714 Member
    103
    17
    Orange County
    And how long do I have to keep it unplugged
  13. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    With what you’re dealing with, having to reset the radio and the windows should be the least of your worries ;).
    JC91006 likes this.
  14. JC91006
    16,478
    8,394
    You need to have that.
    I can help you cause I have the software, but I've never done it either. Here is a video, skip to 1:30
  15. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    I’d say at least 5-10 minutes;).
    But I would do longer to be safe(y).
    JC91006 likes this.
  16. Tony714
    Tony714 Member
    103
    17
    Orange County
    Ooookkkkk Ray. You wanna esplain to me how to do that?
  17. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Let’s clear the brake situation before we muddy the waters with other collateral damage ;).
    Get the brakes sorted and we can walk you through the next steps (y).
  18. Tony714
    Tony714 Member
    103
    17
    Orange County
    All right. So disconnect the battery and then wait 15-20. Is that all I do?
  19. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Don’t close the hatch (or drape a towel across the latch) to avoid the crawl of shame ;).
    Good luck and keep us posted (y).
  20. Tony714
    Tony714 Member
    103
    17
    Orange County
    Appreciated. Will update
