ABS annoying sound
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fakhar87, Mar 9, 2021.
  1. Fakhar87
    Fakhar87 Junior Member
    28
    Pakistan
    Four Touring
    While in parking when i press the brake very annoying sound come from the ABS or driving in slow speed like turning in a very small space it sounds are annoying. Some mechanic says it normal while others says your ABS will definitely throw a code. Does my ABS needs maintenance or what?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    You have a 13 year old car.
    Have the brakes ever had a FULL service during that time ?
    If not, you need to do that NOW.
  3. ChapmanF
    15,572
    Without knowing what kind of sound annoys you, it is very hard to say. Perhaps you could describe the sound in question, or post a recording that isolates it clearly. (That last part is important; many people here will post a recording of an indistinguishable mix of half a dozen sounds the car was making, and even after listening we still have to guess which sound they were asking about.)
    If it sounds a little bit like a metallic rattlesnake, that is the electric pump maintaining your brake fluid pressure, which is its job.
    SFO likes this.
