Abs, brake and anti skid light
Discussion in 'Gen 3 Prius Main Forum' started by Docnadler, Mar 19, 2017.
  1. Docnadler
    Docnadler Junior Member
    florida
    I have 2010 Prius with 180k
    The anti skid light, brake light and abs light all went on
    I brought it to a local mechanic, he checked it out and said he did not recommend that
    I do anything
    Just drive with the lights on!
    Any thoughts or suggestions?
    Thank you
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    700
    274
    Maine
    My 2011 did that.
    It still drove just fine.
    Dealership said it was the brake pump failing. They had never seen one fail before. It took 2 weeks for them to get a replacement in stock, we drove it the whole time with no problems. They finally replaced the pump and it seems fine.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    THIS is an example of why I think that advice to the OP is generally bad.
    If the brake pump completely fails, I think you will have NO BRAKES.
    OTOH, if it is some other component of the ABS system.....like a wheel speed sensor maybe......then you will still have conventional brakes just no ABS, anti-skid or traction control. That still is a risk but fairly small probably.
    You at least need to know what component is failing before deciding what to do (or not do).
    I think a second opinion is in order.
  4. Docnadler
    florida
    The mechanic ran a computer check and the code I believe said wheel sensor
    The car rides fine
    I can't tell about the abs brakes
  5. Sam Spade
    2,036
    1,023
    2017 Prius c
    Any time the ABS warning light is ON, the ABS feature is not functional.
    "Normal" braking will still work though.
    Only you can decide if you want to risk driving it with some of the safety features not working.
    If you can afford to have it fixed, you SHOULD.
  6. ChapmanF
    15,450
    Why not pull the codes and post 'em here? Then we'll have a better idea what the situation is.
    You can do that with a short piece of wire.
    -Chap
    xiiixiixiiix and Raytheeagle like this.
