ABS, Brake and Traction control lights on upon startup.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by h1ph0panonymous, Jun 8, 2025.
  1. h1ph0panonymous
    h1ph0panonymous Junior Member
    91
    17
    2014 Prius - 74k Miles
    Started the car today and the ABS, Brake and Traction control lights were on and stayed on (no blinking).
    Prior to this I had started the car in EV to move the car up the driveway without having to start or use the engine. It rained pretty good for an hour before I did that. No clue why that would cause these lights to turn on on the next start up. I do have a growling wheel hub in the rear (my best guess) for the past week, which growls more and louder around 35 miles per hour or faster, the growling isn’t too loud where you can hear it louder than the engine or radio. I already have a wheel hub with ABS sensor ready to order on RockAuto parts store but I’m not too certain if it’s the front or rear but my best guess is it’s one of the rears, the right rear as I’ve read that one is most likely to be the first one to go bad on average with this generation model.
    I only have a scan 2 reader, no tech stream reader, so I’m out of luck using technology to pin point the issue but I’m assuming something with the ABS speed sensor in the failing wheel hub is the cause, I don’t hear an actuator sound buzzing every so and so seconds as read from other posts, haven’t checked the fluid level yet either.
    Theres a YouTube video showing how to reset the lights with a paper clip put into different slots in the OBD connection and then doing brake pumps, haven’t tried that yet either but want to see if that will clear them in case it was something with the rain that caused it seeing as I didn’t really drive the car before this start up (only moved it a couple feet in EV mode) and to see if the lights come back on after that reset.
    What should I do first, I don’t know how to jack a car up or where to put the jack under the car exactly to not break anything that can’t support the weight of the car (help me out with that) so I can check which tire (wheel hub) has the most play or too much play between all four wheels because I don’t want to pay for a mechanic or dealership to pin point the issue if I can pin point it myself with your guys’ help.
    Thank you in advanced.
  2. Tombukt2
    Tombukt2 Senior Member
    11,992
    2,119
    Durham NC
    Don't do anything until you get the codes read by a proper scanner whether you go to AutoZone using inova 3100 or anything like that your basic scan tool should possibly do what's it show ? Usually in this model don't fool around w paperclips . It's not a thing. You could damage others have . An ap200 in you're future.
    Brian1954 and h1ph0panonymous like this.
    51,013
    is the brake actuator still under the extended warranty?
  4. h1ph0panonymous
    91
    17
    Is my ScanGauge2 reader not enough when it comes to those HUD lights? Just curious what an AutoZone OBD reader can do that my SG2 reader can’t. I’ve read only techstream readers can show your ABS issue codes.
  5. h1ph0panonymous
    91
    17
    No clue but it’s not giving any signs or sounds that it’s the culprit, im leaning more towards wheel hub sensor seeing as all these HUD lights came on a week after my wheel hub started making abnormal growling sounds at higher speeds.
  6. ChapmanF
    17,172
    Not sure what would make Tom say that; blink codes are totally a thing in gen 3 Prius and they're useful if you don't have immediate access to scan tool that can read the codes for you.
    But yeah, don't go fooling around with youtube videos that talk about 'resets'. When your car is telling you a problem, the last thing you want to do is go resetting the information it's trying to tell you. Even if the youtube turns out not to be the wrong way of doing that.
    Instead, follow our page right here at PriusChat that shows the right way to use a paper clip to find out the trouble codes: Blink (a/k/a Flash) Codes – How to. | PriusChat
  7. h1ph0panonymous
    91
    17
    Awesome, now to find a paper clip, yes I figured the reset video was too amateurish to just be a reset procedure rather than a code retrieval process that should be done first before resetting.
  8. Tombukt2
    11,992
    2,119
    Durham NC
    I meant paper clips jumering things for internet resets. Te n e1 or whatever for blinks have been Toyoda thing since ooold days. I'm retarded and mis blinks n shiet . So I guess w tool not guess blinks or do it 5 times and then multiple codes out spend the 63 bux whilst thinking of a Prius purchase it'll work on any car ya buy .and yet prepped . Now you discuss n wait . I can't
  9. Tombukt2
    11,992
    2,119
    Durham NC
    Nope Ap200 bang em RT out for ya set linear valve ster angle add TPMS etc best 64 bux you all spend this year I've this and dealer cf-13 tb w tech I rarely get tech out today only to boot it n use so it don't croak completely
  10. ASRDogman
    ASRDogman Senior Member
    7,108
    3,713
    You need a scanner that can read the Prius ABS system.
    DO NOT "GUESS". You can purchase one from autozone or other parts store
    for about $50. It's likely the a rear hub. You "should" buy both hubs at the same time.
    DO NOT WASTE YOUR MONEY with rock auto. They have cheap chinese parts and won't last.
    Changing a hub on the Prius is not really hard, but it seems you've never done any work on a car
    and it won't be very easy for you. They get stuck on there and can be a royal pain to get off.
    You can just use the jack that came with the car to jack the wheel up high enough to check the hub.
    Don't use it to change the hub because you'll need to back on it. Use a floor jack. And you can put
    it on the control arm where the spring is.
    You probably should seek out a friend that has some experience with cars to help you out.
    Tombukt2 and h1ph0panonymous like this.
  11. h1ph0panonymous
    91
    17
    Thank you good sir, could you refer to me what exactly this reader is, are the ones they let you use for free able to read ABS codes? I’m thinking of doing the flash code retrieval first.
  12. ASRDogman
    7,108
    3,713
    I haven't been in autozone in a while. But it will say on the box if it will read ABS.
    I bought one because they don't lone those out any longer. Maybe where you are they might.
    But that's why I bought one.
    It's easy to miss read the flash codes. And they might not tell the whole story.
    $50 is a good investment. Maybe spend more so it will read Hybrid codes.
    You can also use it on other cars....
    I purchased the Xtools D8 diagnoses tool. It will read almost every car out there and also the
    hybrid codes and readings. It's likely more than you need to spend for your needs.
    It wouldn't hurt to go to autozone and ask them to read the codes. They might have the hubs
    in stock also. Or get them in a day or two.
  13. ChapmanF
    17,172
    ^^^ This.
    Using a scan tool is the more convenient way to go when you already have one.
    When you don't already have one, you've got a car right now that has problems, and you don't know what the problems are, and it is better to know what the problems are, and the blink codes are how you find out, while you work on shopping for a scan tool so you'll have one next time.
    Brian1954 likes this.
  14. h1ph0panonymous
    91
    17
    Update: Neighborhood Mercedes mechanic who also has a super modified Prius gen 3 let me use his innova reader and the codes that came up were C1466 and C1467 which are the ABS speed sensors, one code was for the RH (right hand) and LH (left hand). With that being said along with the wheel hub growling, he said the speed sensor (the main one) is located behind the rear passenger side that connects to the left hand side too. He said my rear brakes need to be changed too but I can only afford to do the front ones which are in worse condition than the rear ones. He said he will instal new brakes and rotors for me and clean the sensors with something which I can’t recall exactly what he said he would use but would you say all arrows point to a new wheel hub assembly that comes with an ABS speed sensor is what needs to be replaced? Haven’t lifted the car to double check which side wheel hub has the most or any play, will do that soon, but the growling isn’t going away any time soon and he said the growling could be from the rear brakes because they are most likely the stock one from 11 years ago.
  15. h1ph0panonymous
    91
    17
  16. ChapmanF
    17,172
    Not sure what he's going on about with a "main one": there's just the four speed sensors, one at each wheel, none is any main-er than the others.
    The two codes are indeed for the rear left and the rear right. Somebody added the troubleshooting steps for those codes as a PriusChat attachment a few years ago:
    https://attachments.priuschat.com/attachment-files/2022/02/218210_C1466.pdf
    As you'll see there, both codes have several three-digit INF codes that tell you more specifically what problem was noted with the sensor signals. You do need a scan tool, though, to get the INF codes. There is no blink version for those.
    While those sensors are located in the rear hub/bearing assemblies, it's not as if bad sensors would be the only way to get a bad sensor signal. You'll notice the troubleshooting steps will only send you to replace the hub/bearing assemblies as the very last step, after ruling out easier things.
    h1ph0panonymous likes this.
  17. ASRDogman
    7,108
    3,713
    Just make sure when the pins on the pucks are aligned with the pads for the rear brakes so the pad
    sits correctly. The guide pins need to be cleaned and regreased also.
    The only way to replace the rear sensors is to replace the hubs. Once you pull the plastic cover off,
    you'll never get it to stick again. Timken or Moog hubs are the best replacement. Unless you want
    to get OEM hubs.
    You can just replace the front sensors, as they are not part of the hub. Brake cleaner works.
    #17 ASRDogman, Jun 8, 2025
  18. h1ph0panonymous
    91
    17
    Guys, I’m literally getting a headache from the paranoia from driving on a bad wheel bearing, I don’t get paid for a week and a half and will have to do at least 500 miles of driving between that time maybe more depending how long the parts take to be delivered. ChatGPT says I have a week or two left based on the signs and symptoms I gave it.
    Im due for an oil change too, on top of the front brakes that need to be replaced and now the back brakes as was told by the neighborhood mechanic, but I have to get the wheel hub(s) changed first, logically and safely speaking. No clue what to do, drive and die or starve and die.
  19. ASRDogman
    7,108
    3,713
    NO ONE can tell you how long you can go with hubs that are making noise.
    Same with the brakes. Best you can get is an estimate. You should do them as soon as possible.
    If either fail, you could cause a wreck. These are just the facts. No one is trying to scare you.
    Well, that's not really true. Some just hate the Prius and want to paint a horrible picture so you
    can suffer like they do. Best to ignore them, for your peace of mind.
    Others know EVERYTHING! And if you don't 100% agree with them, 100% of the time, will
    attack you. Best to ignore them also.
    Owning any car, home, boat, or any other piece of equipment, will cost money to maintain.
    So it's a good idea to set money aside in a fund to pay for future repairs.
    All you can do is get fixed what you can afford to get fixed as soon as possible.
    If you drive easy, and are easy on the brakes, they will last a long time, even if they are thin.
    If you don't have any pulsing when you are applying the brakes, you can likely just replace
    the pads, front and rear, the rotor are fine. I will hit 371,000 miles in the next week and still
    have the same rotors front and back.
    You could get some semi rough sandpaper and sand them down so the new pads will seat in better.
    #19 ASRDogman, Jun 9, 2025 at 7:00 AM
  20. ChapmanF
    17,172
    As you quoted my earlier post, I assume you saw what I wrote about using the troubleshooting steps before you jump to concluding that bearings are even your problem.
    I would happily use ChatGPT any time I needed some text written for me that would convincingly resemble a bunch of other text it had slurped off the internet. I don't generally use it for questions that involve understanding stuff about a car.
