ABS, Brake and Traction lights are on.
Discussion in 'Gen 3 Prius Main Forum' started by Bruce_Rmz, Dec 16, 2025 at 3:20 PM.
  1. Bruce_Rmz
    Bruce_Rmz Junior Member
    Albany NY
    ABS, Brake and Traction lights are on. All three turn off eventually, then after several hours or even after a couple of days, they would come back on. I have not figured any pattern on when they would come on or would turn off. I am getting C1391 and C1241 codes. I am hoping it's not the actual brake accumulator module which would be expensive to replace from what I've seen. My hope is that since the lights go off for a while, it might be just a sensor or a cable that is failing. Please, any advice with any suggestions on what I could check would be greatly appreciated.
    I am not mechanic by any means - I have replaced the break pads before, as well as the spark plugs on this Prius 2013. And that's the extend of what I've done so far on this car.
    When that lights are on, breaks seem be be a little lower -- I mean the break pedal feels like I need to press a little more... the sensation on the break pedal seems to slightly change when the lights go off.
    Thanks All
    #1 Bruce_Rmz, Dec 16, 2025 at 3:20 PM
    51,948
    is the fluid level okay? has the system been bled for any reason?
  3. ChapmanF
    18,215
    C1391 means the car is having trouble maintaining adequate pressure in the brake fluid accumulator.
    C1241 indicates some problem with the 12-volt power supply reaching the brake hardware. It has five different possible "INF codes" that will reveal more about what kind of problem, if you have access to a scan tool that can show the INF codes.
    I would probably try to troubleshoot the C1241 first, on the chance that the problem maintaining pressure could be a consequence of the problem getting 12-volt power.
