abs, brake, traction light on.
Discussion in 'Gen 3 Prius Main Forum' started by Mopar, Jun 30, 2024 at 11:35 AM.
  1. Mopar
    Mopar Junior Member
    Fort Worth Texas
    Troubleshot this and found the rear lh speed sensor wire harness had been broken. I replaced the wire harness and drove the car for a couple days to see if the error light would clear. It did not clear and so I tried disconnecting the battery for about and hour and reconnected. It still did not clear. Is there some way to clear the error lights without the use of a scanner or techstream?
    Thanks,
    Roger
  2. ChapmanF
    15,405
    First you need to find out why those lights are on. Could be the thing you fixed, could be something else.
    If you don't have a scan tool that can show you what the trouble codes are, you can find out this way:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
  3. ASRDogman
    ASRDogman Senior Member
    6,044
    3,245
    Are you sure it's fixed? Maybe another sensor is bad? Or has wiring issues.
    You should get a scanner that will read the ABS system and find out what the issue is.
