ABS, braking power low, etc.
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JennH, Oct 15, 2022.
  1. JennH
    JennH New Member
    Durham NC
    Hi all. I've had my Prius in 4 different times to 3 different shops to figure out why I'm getting these messages: braking power low, abs system malfunction, lane departure alert malfuncion, precollision system malfunction, ICS malfunction. Just brought it back from dealer yesterday who found some air in one of the brake lines and bleed it. This cleared the warnings and code C1214. This morning all the messages are back - considering the paper clip reset but wondering if inputs are same for 2017?
    Ralph Vigil likes this.
  2. Doug McC
    Doug McC Senior Member
    1,004
    377
    Midwest
    2022 Prius
    I’m just wondering, “why 3 DIFFERENT shops?”. Is it a trust issue or convenience?
  3. ChapmanF
    15,617
    What people keep insisting on calling a paper-clip "reset" is merely a trouble-code clear. It is a way of taking a car that has told you there's a brake problem, and making it temporarily forget that it told you there's a brake problem. That'll last as long as it takes for the car to again figure out it has a brake problem, and in the meantime, you're driving around in a car that has amnesia, and a brake problem.
    To your question of whether that method works in Gen 4, I don't know. You could accomplish the same thing (as if there were any good reason to) by connecting a scan tool and doing a code clear that way.
    Earlier generations also had certain other operations, like calibration relearns, that could be done with certain different "paper clip" tricks. I'm not sure whether Gen 4 has those, either, but those are things you do if the trouble codes that you have tell you to do them. (For example, in Gen 3, there can be a trouble code for the linear solenoid offset needing to be learned, so if you have that code, then you go do that procedure.)
    The most urgent thing for you here is to know what trouble codes you have—not to clear them. Do you have a way of getting those codes?
