ABS Braking Situation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fins56, May 12, 2019.
  1. Fins56
    Fins56 New Member
    virginia
    2002 Prius
    Replaced hybrid batteries all lights on dash come on now. trying to find somebody or way to rewire ABS system so can drive 2004 Hybrid. Any ideas
  2. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    You might get more response by moving this to the appropriate subforum.
  3. ChapmanF
    15,614
    Hi ,
    Are you talking about the 2002 Prius in your profile? Or a 2004, um, Hybrid, something? Specifying the car would help, as well as moving the thread to the corresponding forum.
    As far as solving the problem, your best results will be from reading the trouble codes that will tell you why the car has lit those warning lights. The reasons are highly likely to be related to your recent work replacing the battery, and when those are fixed, you should be in business.
