ABS C0210, C1214, U0073
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SirKratosAurion, Dec 13, 2021.
  1. SirKratosAurion
    SirKratosAurion Junior Member
    Somewhere
    Suddenly today when I turned on my prius the ABS, Brake, and Traction lights came on. I had them scanned at autozone and got the codes
    C0210 - Right rear wheel speed sensor signal malfunction
    C1214 - Malfunction in hydraulic system
    U0073 - Control Module Communication Bus OFF
    The Regen breaking is non functional with the break petal, however letting off the gas still regens and so does B position on the shifter. The friction breaks work fine it doesn't feel like the lines have air or are leaking but i did not get to do a visual inspection under the car yet.
    My initial searches came up with this possibly being caused by my bluetooth OBDII and torque app so I followed the Advice to disconnect both batteries and reset the car. The error did not go away.
    I'm going to start by inspecting the right rear wheel speed sensor.
