ABS Codes After Wheel Bearing Replacement
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by AFatGuyInOhio, Jun 1, 2025.
  1. AFatGuyInOhio
    AFatGuyInOhio Junior Member
    United States
    Recently replace the passenger wheel bearing and wheel speed sensor on my 2021 Toyota Prius XLE AWD-e.
    After replacement, basically every error message relating to the ABS actuator is freaking out.
    After extensive research, it looks like it’s a somewhat common ABS glitch that happens with the Prius.
    I believe that jumping the ABS through the pins, pumping the brakes 8 times, and then resetting the car will fix my problem.
    The only issue I have is that I cannot find an OBD2 diagram for the 2021 Prius, and I don’t want to jump it incorrectly.
    It looks like pin 4 is almost always the Chassis Ground, but which pin is the Brake pin?
    Any/all help or suggestions welcome. It is not a faulty wheel bearing or sensor, as we get accurate live data from the sensor.
    Thanks in advance.
