ABS Control Module
Discussion in 'Gen 2 Prius Technical Discussion' started by born2pdl, Dec 31, 2010.
  1. born2pdl
    born2pdl Junior Member
    62
    Utah
    I'm interested in swapping a newer ABS control module into my 05 in an attempt to reduce or eliminate the brake problem others have already described here.
    Where is the ABS module located? If I can find a cheap used one from an 08~09 I'll try it.
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Look for one out of an 09, part number 89540-47130.
