ABS ECU SOFTWARE (UK VERSION)
Discussion in 'Gen 2 Prius Main Forum' started by Firedude, Mar 24, 2025.
  1. Firedude
    Firedude Junior Member
    Pakistan
    Active
    Hi.
    I got 2007 Prius (UK Version). I took it to workshop for mechanical repairs involving welding work. At the end of the day, all yellow lights turned ON & I was told that ABS ECU Software has been erased.
    Can someone guide me where I can get ABS ECU Software (UK Version) downloaded from.
    Regards
  2. Tombukt2
    Tombukt2 Senior Member
    12,141
    2,144
    Durham NC
    Do they have the Toyota tech stream software? I wouldn't think it would make a difference UK or what have you for the brake part of it anyway if it was fuel it might be different but I think the brakes are the same pretty much across the board I would hope doesn't matter where the steering wheel is I just mean the software for the brakes that would be my best guess I wouldn't think this is lost. Maybe they're getting a code that the communication is lost that wouldn't mean that the software is lost that would mean that the computers aren't speaking to each other on the can bus and can't recognize software that it needs on another computer like when your linear valve offset is not been done correctly or it's been lost because you changed the break actuator and now you have to relearn that linear valve offset so pretty much most of the business you're doing should be able to be relearned through the Toyota software one would hope I don't see any downloads from Toyota for brakes software in particular I have about a thousand downloads but I don't see any for brakes or anything.
  3. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    The software is not erased, it remains in the electronic control unit. They are trying to deceive you.
