ABS Failure?
Discussion in 'Generation 1 Prius Discussion' started by ansobu, Sep 11, 2010.
  1. ansobu
    ansobu Junior Member
    2001 Prius
    Hi all, I just bought a 2001 Prius with 68,000 miles. The ABS and Brake lights are lit up on the dash, and I am experiencing some odd braking indeed....
    As far as I can tell, it is not leaking fluid anywhere. I have sufficient braking power for 3-10 seconds, then I seem to lose pressure.
    It's like the ABS pump just stops working, the majority of the time it is fine, however if I am sitting at a light I tend to lose pressure in the system.
    Like I said though, I also have sufficient braking power for 3-10 seconds... So if I stomp the brakes, it stops immediately.
    Another oddity is that when I first get in my car, it feels like my brake pedal has *some* pressure, then it firms right up after 2 seconds of being on the brake pedal.
    Any ideas what this could be?? I checked all of the relays and fuses Mr. Wilson provided to check in the last thread "c1256-low-pressure-accumulator-abs-beepabout" about another ABS failure...
    Any help is appreciated!!!
    FYI I have stopped driving the car because of the brake issue....seems to unsafe for me!
  2. bwilson4web
    15,524
    I wish I could help but brakes are an area of exceptional sensitivity. Personally, I would recommend taking it to a dealer or perhaps the independent mechanics listed in the recent thread. Our brake system behaves differently than ordinary brakes so I would not have much faith in a traditional, brake shop. The mechanic really needs to understand the system.
