ABS kicking in every time I brake
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius2050, Mar 29, 2013.
  1. prius2050
    prius2050 Junior Member
    16
    Stockton CA
    I had an earlier post about issues when braking. The car is jerking forward every time I brake.
    So, today I took the car to my local dealer for a complimentary brake inspection, and they are telling me that the ABS is kicking every time I brake, and that is not suppose to do that. They want $130.00 to do a further diagnostic to tell me what the problem is. I was wondering if any of you guys ever had a problem similar to mine and know what to do about it.
    Thank you..
  2. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Have you fitted any new tyres recently and are all your tyres the same size? Have you any warning lights?
    John (Britprius)
  3. prius2050
    16
    Stockton CA
    No. No waring lights at all; the tires were replaced 4 months ago
  4. Britprius
    5,194
    1,921
    The usual culprits are wheel speed sensors, but these would through a fault code, the brake ECU or the reason I asked one different size tyre that confuses the ECU by giving a different wheel speed for that wheel.
    When you brake the ECU see one wheel going slower and assumes that wheel is beginning to lock, activating the ABS to release the brake on that wheel.
    It may be that a linear solenoid valve calibration is needed. "Dealer only unless you have a mini VCI with Techstream."
    John (Britprius)
  5. prius2050
    16
    Stockton CA
    I do not have a VCI, I will take it back to dealer to see what happens.
    Thanks for your response.
  6. Britprius
    5,194
    1,921
    Please let us know the outcome, hope the cost is not to high.
    John (Britprius)
