ABS Light on
Discussion in 'Generation 1 Prius Discussion' started by sabercat, Mar 31, 2018.
  1. sabercat
    sabercat Junior Member
    48
    Mid-Mich
    2001 Prius
    2001 prius. I just changed the passenger cv axle, after getting it done went for a test ride. Around 40mph the abs light comes on, but like pulling in the driveway at a slow speed the light will go off, and come back on at 40mph. Any ideas? Thanks
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,508
    Bay Area, California
    2019 Prius Prime
    Do you have a code reader?
    Do you feel any difference in performance or hear any audible sounds when the light is on?
  3. sabercat
    48
    Mid-Mich
    2001 Prius
    I have a reader, the cheap one you plug in under the dash. No difference in performance, no sound, brakes work good.
  4. sabercat
    48
    Mid-Mich
    2001 Prius
    on my scan tool, P1430, and 0420
    Raytheeagle likes this.
  5. Raytheeagle
    11,263
    15,508
    2019 Prius Prime
    Well P0420 is for the catalytic converter and P1430 is for a vacuum sensor. Both of these are not for the abs light that’s on:(.
    You’ll need a better code reader to determine the exact cause via the codes ;).
    Know anyone with an old laptop or access to Techstream :whistle:?
  6. sabercat
    48
    Mid-Mich
    2001 Prius
    I'll ask around about the old laptop, and tachstream
  7. EbonBetta
    EbonBetta Junior Member
    47
    16
    palmdale
    2002 Prius
    I
    how much laptop do you need to run techstream ? I have an older netbook I am considering wiping back to square 1
  8. ChapmanF
    17,105
    I'm afraid if I mention this much more often, it'll start to get burned in at the bottom of every PriusChat thread, but anyway:
    Reading the brake system codes does not require any kind of reader at all. You can get finer-grained and additional information if you have one, but you can get the codes with a short piece of skinny wire and some counting of light blinks. (Forum search will turn up the details. Also, it goes without saying, you can find them all in the repair manual.)
    I'm guessing you will find a wheel speed sensor code. While you have the skinny wire handy, there's also an actual speed sensor test described in the repair manual, which is recommended for times when you've worked in that area.
    -Chap
