Abs lights on with check hybrid system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Apatel1101, Feb 28, 2019.
  1. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I have 2010 Base prius with 282K. I got 2 codes for abs, C1300 and U0073.
    Speedometer shows 0mph regardless how fast i go. My car sat for 2 and half weeks and when started i got these lights.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Check your battery voltage
  3. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    12.5v checked this morning with multimeter
  4. tankyuong
    1,555
    661
    Central MO
    12.5 seems low
  5. Wallace Santana
    Wallace Santana New Member
    Las Vegas
    Hi , how are you ? I have the same problem, did you solve this problem ?
  6. ChapmanF
    17,347
    Often "the same problem" posts aren't really about the same problem. The original problem in this thread was:
    Are you for real having exactly the same problem, with the same trouble codes and speedometer reading?
    If not, it will be more fruitful just to describe in detail the problem and the trouble codes your car has.
