ABS module replacement?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hsh, Jan 25, 2018.
Tags:
  1. hsh
    hsh New Member
    Cincinnati, OH
    I have a 2004 Prius with 210K miles. The brakes went out, only work when fully depressing them. Brake warning light and alarm sound. Intermittent: the first mechanic couldn't reproduce and gave up. Got it towed to a hybrid specialist, who diagnosed the ABS hydraulic pump. Wanted a second quote, so called back to the first place. I'm waiting on the quote from them but the guy I talked to was suspicious of the diagnosis, saying he'd never seen that before.
    So, you all would know best. Is it surprising that the ABS module needs to be replaced? Should I be suspicious of the diagnosis?
    There's a good chance I cut my losses on this one anyway but I want to know what I'm dealing with.
  2. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    First, did you get the car scanned for codes?
    Was there any lights on the dash?
    Those are the ???s we need answers to right now.
    Your situation seems similar to an abs pump failure.
    In some cases though, we've heard brakes act that way, without any lights on the dash. So, typically, you might be in for an abs pump module replacement.
    Dxta
  3. hsh
    hsh New Member
    Cincinnati, OH
    Thanks for the reply.
    The red BRAKE light and the buzzer came on. Not sure about the codes, but I think that's how the mechanic diagnosed the problem.
  4. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    His diagnosis is correct then. Get the pump replaced, and that should sort the problem out.
  5. Ryan Harrington
    Ryan Harrington Junior Member
    51
    16
    Louisiana
    Is this the repair that is costing so much money? like $2,000-$4,000? I think I need to replace that on my car. I am fairly confident that I could physically replace the module itself, but with no techstream I don't think I can complete the repair. Is there a cheap way to get techstream so I can bleed the brakes after the replacement?
  6. Brian Andersen
    Brian Andersen Junior Member
    georgia
    Four Touring
    Ryan were you able to repair?? I'm going to purchase a 09 with this problem
  7. JLK_FuelSaver
    JLK_FuelSaver New Member
    Atlanta
    I just bought an 09...hopefully with this problem and not the full ABS module since it's $150-250 more on ebay. So according to my research you need a windows laptop. You can get a Mini VCI cable + software on amazon for about $30-40 and do your diagnostic and clearances from there. I will certainly be posting my codes and continuing updates with this project.
