ABS Problem Help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zulikas, Mar 19, 2013.
  1. zulikas
    zulikas New Member
    Kaunas
    Hi. My toyota prius 2011. have Abs fault codes and not starting. can somebody help me.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You mention a 2011 Prius, but post in a Prius c forum and list yourself as owning a 2012 Prius c. They did not make a Prius c in 2011 so I am unsure where this post belongs.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Moved. To the OP, I'd suggest a trip to the dealer as you're likely still under warranty.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    That is quite a list of codes. I assume that picture was taken at the dealership? Are they not covering the fix?
  5. zulikas
    zulikas New Member
    Kaunas
    I'm a new guy in this forum. sorry. I have to Diagnostic Devices because this photo like a dealer. checked all cables pluses, minuses and can H, can L. All is well good. Then I push brake I can hear the sound which allows ABS block. The dealer say I have synchrnize my ABS ECU with eggine control module. But I do not know how to do it.
