ABS problem
Discussion in 'Prius v Technical Discussion' started by Hassan Ali Beg, Aug 31, 2021.
  1. Hassan Ali Beg
    Hassan Ali Beg New Member
    UK
    ----UK----
    My prius 2011 has got a problem on front right wheel ABS, the code is C02000 Front speed sensor RH Circuit.
    checked the wiring, no cut or harness but no voltage showing when checked with the multi meter. any help please.
    49,398
    maybe it needs to be replaced
  3. gromittoo
    gromittoo Active Member
    718
    286
    philadelphia
    2013 Prius v wagon
    FYI: You posted this in the "Prius v Technical Discussion" forum. The "Prius v" was only made in 2012-2017. Did you mean to put it into the regular Prius Forum? (Not a big deal)
  4. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Guess you answered your own question........ : )
