ABS Sensor Front Left (driver) c0205
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by waldox, May 23, 2018.
  1. waldox
    waldox Junior Member
    69
    toronto
    i have a 2008 prius
    im having problem with code c0205 malfunction of front left sensor
    i replaced the left front sensor and it is still not working
    i looked under the hood to inspect the wiring
    i noticed this connector near where the sensor wiring would be located
    it only had one wire going into it. on the other side the similar connector has two wires going into it. maybe this is the defective wiring and harness clip?
    can anyone check their gen 2 prius and confirm
    if these are not the correct abs connectors please let me know where i can find them
    front left side with only one wire going into connector (bad?) it is located next to front left strut mount
    good two wires going into connector on right front side
  2. waldox
    69
    toronto
