ABS, Traction Control, and Brake lights on with DTC code C0210.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by UltimusTK, Jan 4, 2020.
  1. UltimusTK
    UltimusTK New Member
    Springfield, MO
    Hey everybody, I have a 2010 Prius with 96,000 miles. My symptoms are mushy brakes as well as the brakes do not charge the battery. I recently got techstream so I was able to pull the codes. This is what came up.
    so the DTC code C0210 points to the right rear speed sensor. I have replaced the whole hub assembly, speed sensor included, and the code hasn't changed. I did another health check on techstream and this is what came up after replacing hub assembly.
    I'm just completely lost on where to go now. I'd appreciate any suggestions.
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Sounds like air in the brake line
  3. hwg1996
    hwg1996 New Member
    Baltimore, MD
    Exact same issue. Took it to a Toyota dealer and they said the Reservoir Assembly (part #47220-47080) needed to be replaced.
  4. ChapmanF
    15,662
    Highly unlikely to be the same issue (exact, or even approximate). I see that you've even posted this on another thread where the issue was different from this one, and said it was the exact same issue there too. What gives?
    There are a lot of reasons for brake warnings to come on. As for how often they mean the reservoir needs replacing, well, this is the first case I've seen.
  5. Michael Wood
    Michael Wood Active Member
    179
    118
    Boston, MA
    2020 Prius Prime
    Check with the dealer - there's a warranty extension to 10 years or 150k miles on certain braking system / ABS failures. I got a notice about this in the mail for my Gen III. There's a website where you can enter your VIN to see what's covered.
  6. Riki
    Riki New Member
    Tampa
    Hi there, I have had the same code for a couple of months.
    Prius 2011, 150,000 miles, C0210, The ABS, Slip and both brake warning lights are on.
    The regenerative brake is not functioning.
    A mechanic found out that the electricity is not coming from the wire inside of the body that is connected with the ABS wire harness.
    So the problem should be inside of the body, wires or ECU.
    Any suggestions are appreciated.
    Thank you in advance.
