ABS traction control lights on after rain and puddle
Discussion in 'Prius c Technical Discussion' started by Kelly CJ, May 15, 2018.
  1. Kelly CJ
    Kelly CJ New Member
    Ks
    It stormed like crazy last night and I misjudged a puddle (was deeper than I thought) the ABS light came on and stayed on.
    Brakes seem fine.
    Any idea where to start looking for the problem?
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I would disconnect the 12v battery and reconnect it. See if that clears the code out. If that doesn't work, run a code scan and see what it's complaining about. You may have a damaged sensor.
  3. Leadfoot J. McCoalroller
    7,317
    6,832
    Pennsylvania
    2018 Prius c
    I see this often in Subarus (we play in the mud a bit more)
    Generally the sensor will dry out on its own, and once the code is reset no further action is required. If you're in a hurry you can dry out the sensor more quickly with a hair dryer or a fast drive on a sunny day depending on what's available.
