Abs/ traction control
Discussion in 'Gen 3 Prius Technical Discussion' started by bigblock67, Oct 12, 2018.
  1. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    2014. Both lights on and did try the paper clip trick between #4 and 13 pin.
    Scanner does not depict where issue is. Could use ideas.
    Thanks
  2. ChapmanF
    18,571
    What blinks did you see when 4&13 were jumpered?
  3. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Use better scanner?
    Techstream
