ABS & Traction lights on and off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JarrettOriginal, Dec 3, 2020.
  1. JarrettOriginal
    116
    81
    North Hollywood
    Driving through winding canyons and up and over the Hollywood Hills today,
    my ABS went out and the regenerative brake with it.
    Definitely stressful, but still could stop.
    After parking for an hour, drove her on straight & flat roads, the ABS & all came back, as if nothing had happened.
    Then went away again while going back over the hills and came back again after being parked for a a few hours.
    I don't have an OBDII reader that can access ABS.
    With it being intermittent, does a faulty sensor seem reasonable?
    I just changed all the brakes myself a few weeks ago, but didn't mess with the sensors at all.
    +5mpg for posting
  2. AzusaPrius
    AzusaPrius Senior Member
    1,875
    822
    Try and clean them if you can.
    Yes this is what happens and you will eventually have to replace a speed sensor and if you dont then you will get your hybrid battery weak and get more lights than you want.
  3. ASRDogman
    ASRDogman Senior Member
    6,087
    3,272
  4. JarrettOriginal
    116
    81
    North Hollywood
    My driver's side front speed sensor had broken open and wires were exposed...
    Yikes.
    Easy replacement fix.
    +5mpg for posting
  5. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    It is possible to read the ABS codes without a scanner, by jumpering 3-14 on the OBD port. Count the flashes...
