ABS, VCS, thumping and alarm whistle....
Discussion in 'Gen 2 Prius Main Forum' started by DougDA, Dec 21, 2017.
  1. DougDA
    DougDA Junior Member
    Alabama
    I'm getting all of the above in my wife's 08 prius.
    Audibly i can hear a muted 'thump thump thump thump...." which i'm only assuming is the acumulator?
    Particular car has always had the "stirring" sound behind the inverter which cycles roughly every 12-15 seconds. thats not a new sound.
    so far I have: checked the brake fluid in the reservoir and made sure its topped off.
    checked the aux battery level and it measures 11.4v
    can a battery level just under 12v cause any of this?
  2. ChapmanF
    15,789
    Someone will undoubtedly jump in and say yes, but it won't be me. :) I'd just say go ahead and read your brake trouble codes, more on the soon side, and you can post those here. Feel free to use the jumper wire Tc to CG, count light blinks method, if you don't have a code reading tool.
    -Chap
  3. DougDA
    Alabama
    All I have is an OBDII reader. And it returned a 0011 if I'm remembering correctly. Not sure if that's related.
  4. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    You gotta be sure of the codes your scan tool is returning.
    Get a hybrid compatible scantool and scan.
    Dxta
  5. ChapmanF
    15,789
    or jumper and count the silly blinks, which requires no scan tool at all.
    tomcornell likes this.
