ABS, VSC, PARKING break stay activated
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by camerond, Jun 28, 2016.
  1. camerond
    camerond Junior Member
    Hello all,
    Today I took my 2006 Toyota Prius with 167,000 miles out to drive my dog to the vet. I turned the car on and deactivated the parking break and noticed the light stayed on, then I noticed the VSC and ABS lights stayed on as well.
    My car was parked backwards on a driveway incline for about 14 hours. My 12v battery is old, not sure what shape it is in. The hybrid battery was replaced 2 years ago. I have been reading up and i guess it could be a sensor, skid sensor, 12v battery, or some sort of pump. Also, my parking break has felt a little weak as of late.
    The car still drives, not sure if it drives funny or psychologically I think it does.
    Thanks!
  2. JC91006
    16,827
    8,600
    Go have it checked out, there is an extended warranty for the actuator pump, which has those brake indicators you mentioned
  3. camerond
    Call me ignorant, but how do I check to see if I qualify for the actuator pump extended warranty.
    Thanks
  4. JC91006
    16,827
    8,600
    Just by having a 2006 model. You should have received something in the mail
    This is assuming your hv battery is ok
  5. camerond
    I have moved and I think it might have sent to my old address if they sent it. I tried to go to the website and add my vin but I haven't seen anything about it on there.
    I will call them.
    Thank you
  6. JC91006
    16,827
    8,600
    It's not a recall, it's an extended warranty......in case you encounter the problem
  7. TheNovice
    TheNovice New Member
    Ireland
    Hey guys.
    Hopefully the OP doesn't mind me jumping into his thread! I have the same warning lights appearing and feel another thread would be overkill.
    Anyways I have the red triangle, ABS and VSC lights staying on. I also noticed that the LED that comes on when the "self park" is activated is flashing as opposed to being constantly on, and the cruise control no longer works!
    I've changed the 12V battery, and it wasn't that.
    I've bought an OBDII dongle, plugged it in, downloaded the Torque App on Android and got the following results....
    Vehicle VIN: Not present
    Vehicle Manufacturer: Unknown
    Vehicle Calibration ID: 34712100
    Test report:
    MID:$01 TID:$8e
    - O2 Bank 1 Sensor 1
    Test incomplete or dependant test failed
    MID:$01 TID:$91
    MID:$02 TID:$07
    Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
    MID:$02 TID:$08
    Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
    MID:$02 TID:$8f
    MID:$01 TID:$8e
    MID:$01 TID:$91
    MID:$02 TID:$07
    MID:$02 TID:$08
    MID:$02 TID:$8f
    End of report.
    Strangely, bank 1 sensor 2, which shows as a fail above, is the only thing that gives a "live" graph when the engine is running. Every other sensor in both banks gives a blank graph.
    So does this mean both sensors are gone, or does it mean the cat is acting up?
    Thanks in advance.
    Larry.
  8. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Could be a bad wheel speed sensor. Could also be allot of other things. I had all the same lights and it turned out to be a rear bearing had gone. When it starts to go it destroys the speed sensor.
  9. camerond
    JC91006, I appreciate your help.
    Sorry, I never thanked you for your reply.
    The problem ended up not being the brake actuator. Apparently a rat got into the underside compartment and chewed up some wires.
    $295.00 repair to re-solder the connections.
    fotomoto likes this.
